Does anyone have any suggestions of ways to tame the harsh tin tone from an under the bridge rod piezo ??
taming a Rod Piezo
Originally posted by shortcircuit View PostDoes anyone have any suggestions of ways to tame the harsh tin tone from an under the bridge rod piezo ??This isn't the future I signed up for.
Originally posted by Leo_Gnardo View PostNothing cheap & easy that I know of...
Agree and add: avoid creating a squeaky scratchy frequencyb response in the first place.
Put a 10M input impedance buffer or preamp right in the guitar, less than 12 inches away from pickup.
You´ll be amazed at the now recovered fatness.
And now you have a loud and low impedance signal which can drive any EQ you want to add, even a plain 22k series resistor and 1000pF to 2200pF capacitor to ground.Juan Manuel Fahey
Originally posted by J M Fahey View PostAgree and add: avoid creating a squeaky scratchy frequencyb response in the first place.If you don't know where your going any road'll take you there : George Harrison
Originally posted by J M Fahey View Postdrive any EQ you want to add, even a plain 22k series resistor and 1000pF to 2200pF capacitor to ground.
I built this circuit to try , just because I had all the components on hand
Originally posted by shortcircuit View PostAre you referring to the cap across the tone pot??
[ATTACH=CONFIG]52829[/ATTACH]If it still won't get loud enough, it's probably broken. - Steve Conner
Originally posted by eschertron View PostTo that circuit shown you can add a cap parallel to the 220k resistor which will bleed HF to ground.If you don't know where your going any road'll take you there : George Harrison
Originally posted by J M Fahey View PostBuild it as-is and post results.
Maybe you don´t even NEED treble cutting or if a little, it can be dealt with with standard amplifier tone controls.
I'm sure this isn't what you pictured ,here is where it's going
This is a Lace Alumitone Matchbook pick-up , Bourns 250k push/pull volume splits the Alumitone , Bourns 250k tone with a .022 cap, that all sounds real good. The piezo is in the bridge, the brass pin is my saddle,sitting right on the piezo . Taking your "avoid creating" quote, I've been switching out the brass pin with , bone, plastic, a Q tip shaft (rolled cardboard ??) all with interesting results . I plan on adding a 10k pot from the piezo straight to the jack , so it can be blended with the Lace or singled out. Open to all suggestions they are always appreciated.If you don't know where your going any road'll take you there : George Harrison
Beautiful build, and also the explanation for your harsh unbearable sound: you can NOT repeat NOT connect a Piezo straight to another pickup, or a standard volume control, tone controls, etc; PERIOD.
I´m appalled at your circuit , so I´ll draw something suitable, that beautiful cigar box guitar deserves it.
Your big problem is not in the saddle material or anywhere else, compared to the electrical problem.Juan Manuel Fahey
Ok that would be great, the Alumitone set up was suggested to me by Lace , and it does rock. Am always open for improvements and corrections that's why I'm here to learn from the best!!! Thank you for the build compliment appreciate that.If you don't know where your going any road'll take you there : George Harrison
Originally posted by Leo_Gnardo View PostI found a Tech21 "Acoustic Guitar preamp/DI"If you don't know where your going any road'll take you there : George Harrison
Hi, searched all over the place I have not been able to find a wiring schematic for the Matchbook Alumitone, not even at the Lace page itself https://lacemusic.com/pages/wiring-diagrams
All it says is this, which is incomplete:
https://lacemusic.com/collections/9/...tchbook-pickup
do you have any clickable link?
In any case, also draw and post wiring of what you built, so I can add the piezo buffer and how to interconnect it with the rest of the circuit.
In spme videos I see a bunch of white, red and green wires coming out of the pickup, but nobody shows wiring.
Thanks.Juan Manuel Fahey
Here is what comes with the pick up , and also what Lace sent me.
this is crude but what I did, and I'm happy with this part so far,but always open to other options. The piezo pre amp circuit I built is the one posted earlier I just installed it into an Altoids tin for testing. Really appreciate your helpLast edited by shortcircuit; 03-09-2019, 08:30 PM.If you don't know where your going any road'll take you there : George Harrison
