View Post
JJ6V6 in 6L6 amp
Isn't the XXX just a high gain preamp into a clean power amp? In typical use the power tubes are never clipped so their tonal contribution relative to volume is almost moot. Any tonal change heard when the amp is played louder is more likely to be acoustic changes relative to sheer volume in the room and perceived by your ears. That will be lost no matter how the volume is reduced unless there is another tone altering mechanism to the system by which the volume is reduced."Take two placebos, works twice as well." Enzo
Agree with Chuck, I don't think anyone is ever setting these up clean and cranking the master till the power amp breaks up.
All the high gain tones are achieved through preamp distortion. Power amp breakup might even make it sound worse.
So just turning down the master should achieve the volume reduction.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostI don't think anyone is ever setting these up clean and cranking the master till the power amp breaks up.Last edited by Chuck H; 03-07-2019, 07:21 PM."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostIsn't the XXX just a high gain preamp into a clean power amp? In typical use the power tubes are never clipped so their tonal contribution relative to volume is almost moot. Any tonal change heard when the amp is played louder is more likely to be acoustic changes relative to sheer volume in the room and perceived by your ears. That will be lost no matter how the volume is reduced unless there is another tone altering mechanism to the system by which the volume is reduced.
If it was me I'd just add power scaling to that amp. Then you can get the tone you want at any volume you want. Just power scale the power amp and phase inverter. It will even lower the B+ around 15-20V which might help things. See the link below.
Greg
https://www.londonpower.com/power-scaling
Originally posted by soundmasterg View PostIf it was me I'd just add power scaling to that amp. Then you can get the tone you want at any volume you want. Just power scale the power amp and phase inverter. It will even lower the B+ around 15-20V which might help things. See the link below.
Greg
Originally posted by ultra-gain View Postthanks for the link. I have never heard of this. Probably just use the master volume knob on this amp.
If you don't use the amp at loud volumes, but prefer it's tone when used that way I might suggest that whatever differences in perception volume puts on the ears might be responsible. You could experiment with different cabinets to see if a final EQ/speaker efficiency change helps. There's a noticeable "feel" that comes with speaker efficiency. Speaker hunting can be an expensive drag though. If you're getting satisfactory tone from it as it is then there's really nothing to consider."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostThat IS how the amp was designed to be used. There really is no advantage to the implementation of power scaling for this design.
Originally posted by Chuck H View PostIf you don't use the amp at loud volumes, but prefer it's tone when used that way I might suggest that whatever differences in perception volume puts on the ears might be responsible. You could experiment with different cabinets to see if a final EQ/speaker efficiency change helps. There's a noticeable "feel" that comes with speaker efficiency. Speaker hunting can be an expensive drag though. If you're getting satisfactory tone from it as it is then there's really nothing to consider.
Absolutly, Fletcher-Munson curve. Plus just the sheer force of cranking an amp up loud and pushing some air into your chest and the excitement of an electrified guitar at loud levels.
I'm actually stoked on the sounds I'm getting. Still chasing the perfect medal tone though. Baritone guitar -> Seymour Duncan Black Winter(On order)-> Amptweaker Tight Drive-> Triple XXX->4X12 5150 loaded with Sheffield 1200. I have the Seymour Duncan APH-2 in the guitar now. Hoping the Black Winters set it off.
As long as the curves of different loudness levels run in parallel, there is no change in frequency response perception.- Own Opinions Only -
But we don't count in such studies. Because, deaf rock stars in some or most frequency ranges, anyway! We make terrible test subjects.
Jusrin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
Originally posted by Helmholtz View PostActually the Fletcher-Munson curves show that there is insignificant change in hearing frequency response at different loudness levels at least in the guitar frequency range.
As long as the curves of different loudness levels run in parallel, there is no change in frequency response perception.If it still won't get loud enough, it's probably broken. - Steve Conner
Originally posted by Justin Thomas View PostBut we don't count in such studies. Because, deaf rock stars in some or most frequency ranges, anyway! We make terrible test subjects.
Jusrin- Own Opinions Only -
Originally posted by eschertron View PostI have to ask what curves you are looking at? I see a 20dB difference in the 100Hz - 1000Hz decade. IMHO it's the chest-thumping low notes that indicate loudness for most "test subjects". That's why most cheap 'loudness' controls only boost frequencies.- Own Opinions Only -
