Results 1 to 10 of 10
Thread: EL34 cathode biased question
    Mar 2008
    650
    Received: 54/0
    Given: 154/0
    12
    Hello, I need a suggestion regards the value of resistor / cap for a quad of EL34 cathode biased, please. OT 1.9K, B supply 450V. Thanks
    Let me know if is possible th run it in common mode with a single big power resistor placed somehow external on a heatsink ? The PT spec rated as 400mA for HT winding.
    "If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
    Cheshire, UK
    2,070
    Received: 390/4
    Given: 216/0
    16
    Quote Originally Posted by catalin gramada View Post
    The data sheet says to use individual 465R cathode resistors for 2 x EL34 at 450V but that's with an Ra-a of 6.5k (3.25k for a quad). I think that with a 1.9k OT you'll be in for some crossover distortion and you can't increase the bias current to reduce it without over dissipating the tubes. I have a 30W 2 x EL34 amp running at 375V into a 4K OT. It's fine with either individual 300R cathode resistors or a common 150R resistor.
Name:	EL34 cathode bias.png
    1 Not allowed! Not allowed!
    Senior Member Old Tele man's Avatar
    Oct 2007
    Tucson, AZ
    626
    Received: 54/0
    Given: 4/0
    12
    A single, common, cathode resistor "smooths-out" possible conduction differences between the banked tubes (think "mean" value here), while separate cathode resistors can be individually "trimmed/optimized" to accomplish the same/better results.
    2 Not allowed! Not allowed!
    Jul 2011
    Adelaide, South Oz
    727
    Received: 55/0
    Given: 4/0
    8
    OR
    Be a "smarty trousers" and run
    330 Ohms with 220uF/63V bypass on each tube but instead of returning these to 0V then
    For each push pull pair add a common 68 Ohms unbypassed under the 330 Ohms to 0V.
    That introduces some "conduction balance" and is good to supress some odd order harmonic distortion because of the common mode feedback it introduces.
    Be careful that the common (to 2 tubes) 68 Ohms is on a push pull pair and not on 2 tubes on the same side of the push pull.
    And be aware that this is a "cork sniffer" HiFi trick. You may not want that in your Git Amp.
    Cheers,
    Ian
    5 Not allowed! Not allowed!
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    5,987
    Received: 1,055/15
    Given: 1,009/0
    12
    Quote Originally Posted by Gingertube View Post
    OR
    Cheers,
    Ian
    Hmm I like the smell of cork. It reminds me of victory!
    Might have to try this one on my AC100 Vox. Long time ago, I ran separate cathode resistors & caps. This looks like an interesting variation. Thanx Ginger!
    Enjoy. Every. Sandwich.
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    14,771
    Received: 1,796/4
    Given: 2,005/0
    29
    OR
    Cheers,
    Ian
    Neat-o.
    You could take this a step further and make the shared 68 ohm resistance a 100 ohm power rheostat. It would only need to be a three watt wire wound pot (no bigger and not much more expensive than than a regular pot). That way you have an actual bias adjust and some balancing ability.
    3 Not allowed! Not allowed!
    Valvulados.com jmaf's Avatar
    Apr 2009
    Brasilia
    1,367
    Received: 36/1
    Given: 36/3
    12
    If you want a Marshall sound you'll probably bias at 70%.
    You've got 450 V +B. So you want 156 mA total quiescent current for all 4 x EL34.
    From the following datasheet
    we get that you want the grids at about -28VDC.
    So 450-28 = 422.
    You want 422 volts across the EL34's and 28 volts across Rk.
    28 = Rk * 156mA
    Rk = 179,49 OHMs
    If you want individual cathode resistors, multiply by 4.
    And Bob's your uncle.
    Jul 2011
    Adelaide, South Oz
    727
    Received: 55/0
    Given: 4/0
    8
    jmaf,
    A problem - the curves you are using are for a screen grid voltage of +250V.
    The data Dave H linked is more suitable in this case.
    The "rule of thumb" for the 3rd harmonic cancellation scheme is to use a common resistor equal to 13 to 15% of the single tube cathode bias resistor , hence 68 Ohms as nearest preferred value.
    There are idle currents of 2 tubes in that so it effectively is the same as 2 x 68 = 136 Ohms in each cathode (as far as developing bias voltage goes).
    465 - 136 gives me the 330 Ohms for the individual resistors as the nearest preferred value.
    That is how I arrived at the values in my post. The common resistor needs to be unbypassed. the individual resistors should be bypassed, 220uF is middle ground suggestion but certainly you could try 100uF or 470uF.
    Similarly - for EL84 amps (270 Ohms individual cathode bias is standard) I use 39 Ohms Common and 180 Ohms as the individuals to get an effective cathode bias resistance (per tube) of 258 Ohms
    I occasionally use 2 x 390 in parallel = 195 Ohms instead of the 180 for slightly colder bias.
    Cheers,
    Ian
    Apr 2009
    Brasilia
    1,367
    Received: 36/1
    Given: 36/3
    12
    jmaf,
    Look again on the grid transfer curve I used!
    May 2013
    203
    Received: 4/0
    Given: 10/0
    7
    Cheers,
    Ian
    More on that here: https://www.diyaudio.com/forums/tube...y-huey-46.html
  1. JTM cathode biased
    By Willholmania in forum Guitar Amps
    Last Post: 04-09-2017, 04:21 AM
  2. cathode biased + NFB?
    By daz in forum Theory & Design
    Last Post: 01-27-2010, 01:40 AM
  3. Should I add a bypass cap in a cathode-biased amp?
    By slidincharlie (Carlo P) in forum Mods & Tweaks
    Last Post: 11-14-2009, 10:31 PM
  4. Post PI MV on cathode biased amp
    By MikeT in forum Theory & Design
    Last Post: 01-12-2009, 11:28 PM
  5. Replies: 5
    Last Post: 11-26-2008, 11:34 PM
