Results 1 to 9 of 9
Thread: Fender Blues Deville power transformer
  1. #1
    Twobie
    Join Date
    Mar 2019
    Posts
    3
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Rep Power
    0
    Arrow Fender Blues Deville power transformer
    I am building an amp using circuit boards and original output transformer from a 1994 Fender Blues Deville. I don't need a 60 watt amp. Can I use a power transformer from a Blues Deluxe to reduce wattage? Will it be compatible with the original Blues Deville output transformer or should I also buy a Blues Deluxe OT? Many thanks for your help.
    0 Not allowed! Not allowed!
  2. #2
    Supporting Member loudthud's Avatar
    Join Date
    May 2006
    Location
    Near Dallas Texas
    Posts
    3,489
    Thumbs Up/Down
    Received: 158/0
    Given: 95/1
    Rep Power
    18
    The B+ isn't much different between the two, 427V vs 471V. The Blues Deville OT will tend to pull too much current. The Blues Deluxe OT is a much better match for the Blues Deluxe PT.
  3. #3
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    1,537
    Thumbs Up/Down
    Received: 1,135/1
    Given: 693/2
    Rep Power
    4
    I don't think so. The influence of OT size and efficiency on power supply current is insignificant.
  4. #4
    Bent Member Chuck H's Avatar
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    14,807
    Thumbs Up/Down
    Received: 1,843/4
    Given: 2,065/0
    Rep Power
    29
    I expect loudthud is considering a certain (incompatible?) tube relative the OT's load and the final affect on the whole circuit.?. I wasn't clear on it either but Mr. thud knows his stuff so I'm sure there's logic that wasn't made clear.
    1 Not allowed! Not allowed!
    "Never bet your life on somebody else doing their job." SoulFetish's good friend
    "Being born on third base and thinking that you must have hit a triple is pure delusion!" Steve A
    "Back to the amp. It makes horrible sounds when I play my guitar thru it... because I suck at playing guitar." Mike6158
  5. #5
    Old Timer
    Join Date
    May 2006
    Location
    Chill-Ville, VA
    Posts
    3,005
    Thumbs Up/Down
    Received: 563/5
    Given: 1,025/9
    Rep Power
    17
    They both use a pair of 6L6GC... And does an OT "pull current," or do the power tubes do that?
    This was in response to Chuck's mention of different "(incompatible?)" power tubes.
    Justin
    2 Not allowed! Not allowed!
  6. #6
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    14,807
    Thumbs Up/Down
    Received: 1,843/4
    Given: 2,065/0
    Rep Power
    29
    I admit I didn't look into it. I just grabbed at the first thing I could think of to make sense of things.
  7. #7
    Join Date
    Feb 2010
    Location
    Posts
    11,333
    Thumbs Up/Down
    Received: 1,290/21
    Given: 3,217/8
    Rep Power
    22
    Maybe having to do with the primary Z of the OT?
    Just because they don't have tubes doesn't mean they don't have feelings! - glebert
  8. #8
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    1,537
    Thumbs Up/Down
    Received: 1,135/1
    Given: 693/2
    Rep Power
    4
    Quote Originally Posted by g1 View Post
    The 2 OTs are used by Fender in essentially the same power circuit, the main difference being about 10% less HT voltage in the Blues Deluxe. I assume that both OTs have a primary Z of 4 k to 5k.
    Even if the primary Z would differ by say 20%, the current source character of pentodes/tetrodes wouldn't allow for much influence of load Z on (total supply) current. The Blues Deville OT may have 5% less losses and thus produce 5% more output but also this would not reflect in different supply current as the power input to both OTs would be the same.
  9. #9
    Twobie
    Join Date
    Mar 2019
    Posts
    3
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Rep Power
    0
    Thumbs up Fender Blues Deville power transformer
    Quote Originally Posted by lexluthier2019 View Post
    Many thanks to all for responding to my question and for your advice. I truly appreciate it. As the cost for a just a power transformer for a Blues Deville is similar to the cost for Blues Deluxe power and output transformers together I can now make a better decision as to what to order. This will be an interesting project.
Thread Information
Users Browsing this Thread
  1. Fender Blues DeVille Faceplate?
    By Mark Black in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-18-2019, 11:30 AM
  2. Fender Blues Deville Issues
    By greenmeanh1 in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-07-2017, 11:35 PM
  3. usa fender blues deville 410 problem
    By bluestom50 in forum Music Electronics
    Last Post: 06-11-2013, 09:07 PM
  4. Fender Blues Deville - No Reverb
    By Wildcard in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-20-2011, 12:23 PM
  5. Fender Blues Junior power transformer
    By mark h in forum Mods & Tweaks
    Last Post: 07-10-2009, 01:01 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
