I am building an amp using circuit boards and original output transformer from a 1994 Fender Blues Deville. I don't need a 60 watt amp. Can I use a power transformer from a Blues Deluxe to reduce wattage? Will it be compatible with the original Blues Deville output transformer or should I also buy a Blues Deluxe OT? Many thanks for your help.
Fender Blues Deville power transformer
The B+ isn't much different between the two, 427V vs 471V. The Blues Deville OT will tend to pull too much current. The Blues Deluxe OT is a much better match for the Blues Deluxe PT.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Originally posted by Helmholtz View PostI don't think so. The influence of OT size and efficiency on power supply current is insignificant."Take two placebos, works twice as well." Enzo
They both use a pair of 6L6GC... And does an OT "pull current," or do the power tubes do that?
This was in response to Chuck's mention of different "(incompatible?)" power tubes.
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
I admit I didn't look into it. I just grabbed at the first thing I could think of to make sense of things."Take two placebos, works twice as well." Enzo
Originally posted by g1 View PostMaybe having to do with the primary Z of the OT?
Even if the primary Z would differ by say 20%, the current source character of pentodes/tetrodes wouldn't allow for much influence of load Z on (total supply) current. The Blues Deville OT may have 5% less losses and thus produce 5% more output but also this would not reflect in different supply current as the power input to both OTs would be the same.Last edited by Helmholtz; 03-09-2019, 10:16 PM.- Own Opinions Only -
Originally posted by lexluthier2019 View PostI am building an amp using circuit boards and original output transformer from a 1994 Fender Blues Deville. I don't need a 60 watt amp. Can I use a power transformer from a Blues Deluxe to reduce wattage? Will it be compatible with the original Blues Deville output transformer or should I also buy a Blues Deluxe OT? Many thanks for your help.
