Results 1 to 5 of 5
Thread: Akai S900 non functioning and blocks on display
    Sep 2012
    South coast UK
    620
    Received: 9/0
    Given: 18/0
    7
    Hello
    This is a bit out of my comfort zone.
    Regular customer asked me a few weeks ago to re cap his psu for this unit
    which i did and could not test as i just had the psu pcb without an transformer
    It was checked over about twice and all was correct
    On fitting he said all was well and no issues. for a few weeks
    He decided to change the floppy drive for a usb .
    He did that himself .
    After he did that he said that the unit stop functioning and the display got all scrabbled
    The leds on the front seem to flickering
    He brought it in to me.
    I have tested the psu and all voltages are correct , checked all connections and looked over for dry colder joints/ broken wires etc
    To be fair its out of my comfort zone, I would normally not touch,
    This is a link to a PDF on the net
    http://www.polynominal.com/site/stud...ice-manual.pdf
    many thanks in advance
    bbb
    Sep 2011
    Pace, FL
    2,795
    Received: 813/100
    Given: 113/33
    10
    Quote Originally Posted by blindboybenton View Post
    Hello
    bbb
    Logically going forward, all he did was change the floppy drive for a usb. Do you have the floppy drive? Can you reattach it and see what happens?
    The floppy connector typically has a +5 and a +12 while USb typically has +5v.
    Look at the plug and see how feasible it is that is was plugged in reverse.
    Check the board for regulators and see if they're putting out correct voltage, reseat connectors verify correctly inserted, etc etc..
    nosaj
    Oh and this might help
    Sep 2012
    South coast UK
    620
    Received: 9/0
    Given: 18/0
    7
    thanks Nosaj
    The first thing i did was remove the usb module that was fitted and i don't have the floppy, about a decade ago i would of had one in my bits draw.
    all voltages on the psu board are present and correct one of the first things i checked.
    One thing stuck in my mind, when he dropped it off, he said he changed the floppy to usb, not 100% if he said did somehing else aswell
    Sep 2011
    Pace, FL
    2,795
    Received: 813/100
    Given: 113/33
    10
    thanks Nosaj
    Well at this point I would check voltages at the LCD module, possibly read through the service manual I sent. I've got to go to Chuckie Cheese for a party, yay!
    nosaj
    Please disconnect and reconnect every cable in the box. Then follow up with any change in operation.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    31,532
    Received: 1,419/7
    54
    Whenever you work on something and it all of a sudden has a new problem, it almost always is something you did. He might have misconnected a cable, might have broken a solder joint, etc. May have caused a static discharge that scrambled memory.
    Fist thing I'd do would be re-initialize the unit - "restore factory settings" in many manuals.
    And Nosaj is right, reseat all the connectors.
  1. Building Blocks Series
    By nosaj in forum Music Electronics
    Last Post: 11-18-2018, 02:58 AM
  2. the ol' hot rod deville...more drive not functioning
    By doctorfate in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-12-2010, 08:00 PM
  3. JCM 800 poweramp not fully functioning
    By BeëlzeM in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-30-2009, 01:27 PM
  4. trem blocks and weight
    By daz in forum Guitar Tech
    Last Post: 03-09-2009, 06:32 PM
  5. Radius Sanding blocks
    By Dansk_84 in forum Guitar Tech
    Last Post: 09-22-2008, 10:24 PM
