Ampeg- what are these?
They are supposed to hold the footswitch. You slide the footswitch between the two plastic extrusions. The back panel has a little notch cut out so that the footswitch will slide under the cross rail.
The footswitch was an accessory, not included with the amp, which is why you don't see many of them.
Personally I loved the idea of the hard-wired footswitches; I had them in my Reverberocket 2s. Of course, I've also seem plenty of Ampegs where someone had just cut the cord & tossed the switch, too...
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
Ah, yes.
The cut out on the back panel....it all makes sense now.
It's like all those 70's Peavey amps.
Din connector to switch a bunch of features but you never see the footswitch.
I've made up a few for some people and actually made one for an Ampeg G12 where someone lopped off the footswitch.
