Results 1 to 31 of 31
Thread: Please Help !!! fixing a Tone Bone Plexitube Distortion Pedal
  1. #1
    Junior Member
    Join Date
    Mar 2019
    Posts
    15
    Thumbs Up/Down
    Received: 0/0
    Given: 1/0
    Rep Power
    0
    Question Please Help !!! fixing a Tone Bone Plexitube Distortion Pedal
    Hi,
    I've connected my ToneBone plexitube Hot British Distortion Pedal to a MOOER PowerBank.
    first to the 15V and the power bank shut off.
    then i've tried connecting it to the 12V and after a few seconds smoke came out.
    Upon inspection it seems that only the capacitor got burnt -
    I'm hoping that it is only a matter of replacing this capacitor.
    However because it is burnt i can't know what capacitor to buy.
    the capacitor definitely looks burnt but it tweets on continuity check in the multimeter.
    I don't know much about electronics and can't figure out what to do. the schematics for other products don't realy help me -
    The capacitor is C21 in the Plexitube Hot British Rev 0A 29-8.
    I'm hoping someone here can help me figure out this otherwise I'd have to go to a propper lab to get it fixed.
    I've sent a help request to Radial Engineering Hoping they'd help me.
    Thank you.
    0 Not allowed! Not allowed!
  2. #2
    Master Destroyer nosaj's Avatar
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    2,794
    Thumbs Up/Down
    Received: 811/100
    Given: 113/33
    Rep Power
    10
    Quote Originally Posted by Iddo View Post
    Hi,
    Thank you.
    Lets have some pics of the pcb please.
    nosaj
    Only schematic I could find.
    http://www.dirk-hendrik.com/temp/ton...ot_british.pdf
    Binkie McFartnuggets‏:If we really wanted to know the meaning of life we would have fed Stephen Hawking shrooms a long time ago.
  3. #3
    Join Date
    Feb 2010
    Location
    Posts
    11,203
    Thumbs Up/Down
    Received: 1,161/21
    Given: 2,934/8
    Rep Power
    22
    Near as I can tell, the tonebone wants 15V, tip positive. The MOOER supply is tip negative, so it is the wrong polarity for this pedal.
    Most likely components that got fried are shown as D1 and C27A on the schematic posted by nosaj.
    Just because they don't have tubes doesn't mean they don't have feelings! - glebert
  4. #4
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    2,794
    Thumbs Up/Down
    Received: 811/100
    Given: 113/33
    Rep Power
    10
    Quote Originally Posted by g1 View Post
    I was kinda thinking that might've been a possibility but didn't get to researching the mooer.
    nosaj
  5. #5
    Junior Member
    Join Date
    Mar 2019
    Posts
    15
    Thumbs Up/Down
    Received: 0/0
    Given: 1/0
    Rep Power
    0
    Smile PICS
    thanks for the quick reply.
    here are the pics
    https://ibb.co/QQc6ytq
    to the left between the DC in Jack and the potentiometer is the burnt capacitor
    also below the 4th potentiometer from the right there is something that might be burnt plastic which i haven't noticed at the begining.
    a pic of the small plastic blob https://ibb.co/x1rZ9Q8
    to the left of the dc jack the burnt capacitor https://ibb.co/b6kPBnG
    does anyone know if i'm elligible for warranty after making such a stupid mistake ? it's brand new and i barely used it.
    i also ask if i can use continuity check on a powered on board like this or is it too risky ?
    do capacitors and resistors respond to a continuity check ?
    Thanks for the support very much appreciated.
  6. #6
    Junior Member
    Join Date
    Mar 2019
    Posts
    15
    Thumbs Up/Down
    Received: 0/0
    Given: 1/0
    Rep Power
    0
    yes your'e right. the funny thing is that when connecting to 12v the mooer didn't shut down while in 15v it did. the polarity is the opposite to boss effects which work fine. such a stupid mistake. lesson learned the hard way.
    Thank you for the reply - much appreciated.
  7. #7
    Junior Member
    Join Date
    Mar 2019
    Posts
    15
    Thumbs Up/Down
    Received: 0/0
    Given: 1/0
    Rep Power
    0
    the c27a says 47/16 - what does that mean ? what should i ask for in the store ?
    also the diode D1 - should i just ask for a 1N4001 diode ?
    how do i know which way to connect the capacitor - the black and white on the schematic what is the positive and what is the negative ?
    also how do i tell the positive and negative on the newly purchased capacitor ?
    i apologize for asking such novice questions but all i know about electronics is from a fourth grade hobby course. :-)
    thanks.
  8. #8
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    2,794
    Thumbs Up/Down
    Received: 811/100
    Given: 113/33
    Rep Power
    10
    here are the pics
    The piece of black plastic your reference is most likely the outer sheath of the capcaitor.
    Warranty, not likely.
    Continuity check on a powered board? Don't even think about it, Now with no power connected then yes it's ok, just don't plug it in. When it's powered you will use the voltage portion of the meter.
    nosaj
    Depending on the DVM resistors will up to a point choose Ohms and verify by the stripe code.
  9. #9
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    2,794
    Thumbs Up/Down
    Received: 811/100
    Given: 113/33
    Rep Power
    10
    thanks.
    47uf 16v Which means the caps are riding on the edge, I'd at least put in a 25v. Probably easier to get a 1n4007 which will work the same.
    How else you gonna learn if you don't ask?
    The only stupid question is the one you don't ask.
    nosaj
    4 Not allowed! Not allowed!
  10. #10
    Junior Member
    Join Date
    Mar 2019
    Posts
    15
    Thumbs Up/Down
    Received: 0/0
    Given: 1/0
    Rep Power
    0
    Thanks nosaj i really appreciate the help. i am afraid of touching the board but it seems that i have no choice. i have a 65W soldering iron and i ordered one with thermal control. what temperature should i use so i don't do more damage ?
    I'll wait a couple of days and see if i get an answer from Radial.
  11. #11
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    2,794
    Thumbs Up/Down
    Received: 811/100
    Given: 113/33
    Rep Power
    10
    Since this will be your first foray.. please go find a broken electronic device somewhere, open it up and start removing things. My iron uses Celcius I usually have mine set around 390-400C , I will also use some new solder to wet what I want to remove it seems to make it easier to remove when using a solder sucker. Solder wick I've never successfully used so I can't comment on that.
    Always practice something new first on a donor.
    nosaj
  12. #12
    Junior Member
    Join Date
    Mar 2019
    Posts
    15
    Thumbs Up/Down
    Received: 0/0
    Given: 1/0
    Rep Power
    0
    yes i've started practicing.
    radial just answered me - "
    I am sorry to hear about your Plexitube. All Radial and Tonebone devices that require our 15V power supply are all fed with a center-pin positive polarity.
    The Mooer power supply supplies center-pin negative polarity only—it sounds as if you fed your Plexitube with the incorrect polarity.
    The capacitor at C21 is a 10µF 35V tantalum capacitor.
    Further, I spoke with my service technician about your Plexitube. He recommended changing the diode at D1 as well since this occurred. The diode is a 1N4001 diode."
    so g1 got it right with the diode.
    i'm not sure how to deal with the black blob thing - either try to remove the blob without damagin the board from above or desoldering from below and then taking out the blob mass - lol
    Thanks again
  13. #13
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    2,794
    Thumbs Up/Down
    Received: 811/100
    Given: 113/33
    Rep Power
    10
    Thanks again
    Based on that it probably stands to reason the schematic I posted is not the same as your board.
    nosaj
  14. #14
    Old Timer
    Join Date
    Jun 2007
    Posts
    5,074
    Thumbs Up/Down
    Received: 69/0
    Given: 48/0
    Rep Power
    18
    Do you have a multimeter that can test diodes?
    The burnt yellow cap next to the power jack is definitely a tantalum cap, so get one like they told you, to replace it. The board will probably be marked with a polarity marking to show you how to install the new one. The new cap will have a polarity marking on it or at least the two leads will be of different lengths to show the polarity.
    The black blob is epoxy or encapsulation medium put on the board to cover up part of the circuit that the manufacturer does not want people to see. You probably will not need to do anything with it, in order to fix the pedal.
    1 Not allowed! Not allowed!
  15. #15
    Junior Member
    Join Date
    Mar 2019
    Posts
    15
    Thumbs Up/Down
    Received: 0/0
    Given: 1/0
    Rep Power
    0
    i'm so relieved to hear that. so i hope this should be quite an easy repair. that was my initial thought but then my mind started going for worst case scenarios. :-)
    Thanks Bill
  16. #16
    Supporting Member eschertron's Avatar
    Join Date
    Aug 2012
    Location
    Great Black Swamp
    Posts
    2,129
    Thumbs Up/Down
    Received: 332/0
    Given: 813/1
    Rep Power
    9
    Thanks Bill
    My worst-case scenarios always involve me being impatient. So my advice is take it slow. And practice on some broken thing before you approach the pedal - as advised before.
  17. #17
    Junior Member
    Join Date
    Mar 2019
    Posts
    15
    Thumbs Up/Down
    Received: 0/0
    Given: 1/0
    Rep Power
    0
    hi,
    some progress made - i've replaced the capactior and the diode. the shop gave me a 1N4007 instedat of a 1n4001 and just like nosaj said it should work.
    i was so thriled that it did turn on but it sounds like this - (the changes in volume is because i'm turning the pedal's level knob while recording)
    https://we.tl/t-gUqUmUh9rS
    then i took out the 4007 and replaced it with the original 4001 and it turned on but still sounds like some power tool :-)
    where should i go from here ?
  18. #18
    Lifetime Member Enzo's Avatar
    Join Date
    May 2006
    Location
    Lansing, Michigan, USA
    Posts
    31,532
    Thumbs Up/Down
    Received: 1,419/7
    Given: 0/0
    Rep Power
    54
    1N4001 and 1N4007 are electrically the same other than high voltage rating. If one sounds different, it is because one is defective.
  19. #19
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    2,794
    Thumbs Up/Down
    Received: 811/100
    Given: 113/33
    Rep Power
    10
    hi,
    To say this could be a very involved repair is an understatement. We do not have a schematic that correlates to your board, so there will be guesses here.
    Based on your info provided and the schematic I found I am thinking you replaced C6 on the schematic I have. If that has any similarity to your board then it's very possible U4 is out (I'm not real sure if Voltage regulators handle reverse polarity or not).
    The only things I can think of to see if anything can be narrowed down is to pull the tube and see if it's still making noise, see if the switches changed removed the noise(with and with out the tube). Check the voltage at pins 1 and 6 on the tube socket.
    Just understand we're working on for example here's an anology. Say we have a map of Florida from the 1950's and we're now in 2019. A lot of things can be very similar but also different.
    nosaj
  20. #20
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    1,361
    Thumbs Up/Down
    Received: 967/1
    Given: 637/2
    Rep Power
    4
    hi,
    Did you verify (by measuring inside the pedal) that the pedal actually gets full 15V from the powerbank? This is also to make sure that the powerbank still works properly and wasn't damaged by the wrong polarity connection.
    If so the next step would be to verify the 12V after 7812 regulator which feeds the tube heater and then the +/- 6V opamp supply voltages.
    Do we have a valid schematic from Radial?
  21. #21
    Junior Member
    Join Date
    Mar 2019
    Posts
    15
    Thumbs Up/Down
    Received: 0/0
    Given: 1/0
    Rep Power
    0
    ok first thanks a lot about the help everybody !!!
    Helmholtz - I am using a 15v stabilized transformer. the Mooer powerbank is fine.
    1. now some question for nosaj you said to check the pins - and Helmholtz you said to check the voltage - but how can i check if the power is down - nosaj you said not to check when the circuit is on ?
    2. are these voltage regulators - https://upload.wikimedia.org/wikiped..._regulator.jpg
    and if so do you mean the one just to the right of the capacitor i replaced (labeled Q1 in my pedal) or the two below the fifth potentiometer from the right (labeled Q7 and Q8) ? or all of them.
    3. what is U4 I can't find any U on the circuit ?
    i also thought maybe I should reverse the capacitor maybe i put it wrong ?
    Thanks.
  22. #22
    Junior Member
    Join Date
    Mar 2019
    Posts
    15
    Thumbs Up/Down
    Received: 0/0
    Given: 1/0
    Rep Power
    0
    clean sound - bypass is working great - with and without a tube - but any distortion sounds horrible - taking the tube doesen't seem to solve anything. as far as i can tell the tube looks ok
  23. #23
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    1,361
    Thumbs Up/Down
    Received: 967/1
    Given: 637/2
    Rep Power
    4
    What do you mean with stabilized transformer? A regulated DC power supply?
    To check operating voltages, the circuit has to be powered.
    The Uxs in the schematic of post #2 are designators of integrated circuits. The Qs mean transistors.
    I suggest to start with measuring the heater voltage of the tube between pin #4 and #5. Should be 12VDC. Pin #4 and PIN #5 should each measure +/- 6VDC to circuit ground.
    As already noticed, the reference numbers/labelling of components may differ from schematic to actual circuit board. And we are not sure if the schematic is valid.
  24. #24
    Junior Member
    Join Date
    Mar 2019
    Posts
    15
    Thumbs Up/Down
    Received: 0/0
    Given: 1/0
    Rep Power
    0
    Hi Helmholtz - yes it's a regulated DC power supply.
    regarding the IC's - as far as i can tell there are only two visible - maybe there's also one in the epoxy covered as well - anyway, one says -
    O72D
    JRC
    H023B
    and the other reads:
    OP725
    G #1711
    3776788
    i am getting approx 14.6V on the 7821 voltage regulator.
    now the tube is a crecent so looking from the outside where the joints are made i am going clockwise counting from the hollow of the crecent - so between 4 and 5 there is 14.5V.
    nosaj sorry for the question - only continuity is forbidden - now i get it.
    how can i check the two IC's ?
  25. #25
    Junior Member
    Join Date
    Mar 2019
    Posts
    15
    Thumbs Up/Down
    Received: 0/0
    Given: 1/0
    Rep Power
    0
    offtopic question
    i hope it's ok with you i'd like to know in this schematic -
    http://zappers.narod.ru/originalzapper.gif
    where the lines cross but there's no dot that marks a connection neither a loop above that marks they are not crossed - like the line going from C1 down - is it connected with the line going down from leg 1 of the 555 ?
    and also do you have a recommendation for some basic beginner's guide - book, videos whatever works ?
    Thank you
  26. #26
    Supporting Member Jazz P Bass's Avatar
    Join Date
    Dec 2008
    Location
    Wernersville, PA
    Posts
    12,691
    Thumbs Up/Down
    Received: 358/2
    Given: 190/0
    Rep Power
    25
    The 'old school' way of drawing a line that crosses but does not connect was to put a hump in the line.
    The 'new' way is to simply draw the line directly across the other.
    If there is not a 'dot', then there is no connection.
  27. #27
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    1,361
    Thumbs Up/Down
    Received: 967/1
    Given: 637/2
    Rep Power
    4
    14.6V at the regulator output and more or less the same at tube heaters is close or the same as the power supply input voltage and means that the 12V regulator IC (7812) is defective.
  28. #28
    Junior Member
    Join Date
    Mar 2019
    Posts
    15
    Thumbs Up/Down
    Received: 0/0
    Given: 1/0
    Rep Power
    0
    Thanks Jazz P Bass
  29. #29
    Junior Member
    Join Date
    Mar 2019
    Posts
    15
    Thumbs Up/Down
    Received: 0/0
    Given: 1/0
    Rep Power
    0
    Helmholtz so, do you recommend trying to change the voltage regulator and see where to continue from there ?
  30. #30
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    1,361
    Thumbs Up/Down
    Received: 967/1
    Given: 637/2
    Rep Power
    4
    It is probable that there is more damage than just the regulator IC. If you don't understand what you are doing, you might easily cause more damage.This might be a job for a professional technician with signal generator and scope.
  31. #31
    Junior Member
    Join Date
    Mar 2019
    Posts
    15
    Thumbs Up/Down
    Received: 0/0
    Given: 1/0
    Rep Power
    0
    Thanks Helomholtz
Thread Information
Users Browsing this Thread
  1. Anybody have a schematic of Radial Tonebone Plexitube?
    By Ramsay in forum Guitar Effects
    Last Post: 10-20-2013, 08:15 PM
  2. big daddy distortion pedal
    By walcen in forum Guitar Effects
    Last Post: 08-22-2012, 02:07 PM
  3. Which Distortion Pedal
    By MattyTheGuitarist in forum Guitar Effects
    Last Post: 02-24-2009, 07:41 PM
  4. Anyone used this old distortion idea in a pedal?
    By Sock Puppet in forum Guitar Effects
    Last Post: 07-19-2008, 04:50 PM
  5. Bone or Tusq ?
    By Jammin'John in forum Guitar Tech
    Last Post: 01-18-2008, 11:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
