Results 1 to 4 of 4
Thread: Taming a Boss Hyper Metal HM-3
    Feb 2010
    535
    Received: 3/0
    10
    Greetings, folks. Haven't posted on music-electronics-forum in a few years, life has changed and I don't play much with amp repair lately. However, I messed with a Boss Hyper Metal HM-3 last night and I thought I would pass on my results. This pedal came to me several years ago but I never used it; my metal days are far behind me, and even at its lowest distortion setting this was a 1980's "angry box of bees" sound--at higher settings, think Swedish Death Metal. I wanted something more Tube Screamer-ish. This isn't a highly-demanded pedal so selling it would not have gotten me much cash, might as well try to play with it.
    Schematic is posted below. First step: lift one leg of D5 and D6 (shunt clipping diodes). Still way over-the-top, too much gain. Hmm, from my fuzzy recollection of a Tube Screamer, isn't this pedal kinda the same topology as a TS? I found R. G. Keen's excellent writeup on the anatomy of a TS, and whadya know, this HM3 is very similar, only with an extra gain stage and a slightly more complex tone stack. First gain stage half of the HM3's IC can give gain from unity to about 240, second stage gives a gain of about 10. Let's make a simple change: reduce gain to about 1.5 in the second half by changing R12 to 33K.
    Wham...huge difference. At lowest Dist level, a slight boost but still quite clean, increasing the level gives progressively more dirt until maxed out, when there's still some serious distortion. I call this mod a winner!
    Oh, this is not SMT and is easy to work on, by the way; merely undo the four screws for the bottom plate and the PC board gently pries out.
    Summary...lift one leg from D5 and D6 and change R12 to 33K and this becomes a nice boost/overdrive pedal.
Name:	HM3 schematic.PNG
    3 Not allowed! Not allowed!
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,753
    Received: 1,883/23
    Given: 1,463/35
    27
    Excellent mod
    And yes, "there´s a hidden TS" inside, so you can downplay gain as needed.
    If still buzzy you may even lift one leg of C11 .
    Tone controls by themselves do not hurt, since you can set them as you like, including flat.
    But sadly you left out the most important mod
    1 Not allowed! Not allowed!
    Feb 2010
    535
    Received: 3/0
    10
    Thanks Juan! Painting it green did not occur to me...uh wait, though, paint costs money...
    Sep 2007
    Sweden
    163
    13
    When lifting the diodes you increased the signal level going to the eq. That will get you distortion when turning up the controls on the eq. Theres not much headroom in a 9V system. I would lower the signal going to the eq to the same level as when the diodes where there.
  1. Boss Metal Zone MT-2 Help Needed to fix.
    By JohnR242 in forum Guitar Effects
    Last Post: 10-11-2019, 05:07 PM
  2. Boss Metal Zone - No clean tone!
    By Sub-Zero in forum Music Electronics
    Last Post: 03-18-2016, 10:56 AM
  3. Taming high B+
    By Rhodesplyr in forum Other Amps
    Last Post: 08-08-2014, 05:26 PM
  4. Replies: 7
    Last Post: 04-26-2007, 09:40 PM
