Epiphone Valve Standard standby switch?
  • Epiphone Valve Standard standby switch?
    Got a Epiphone Valve Standard needs a new standby switch, Where might I source one from?
    Thanks,
    nosaj
    Look in MOuser. Measure the mounting hole in teh panel. Then look for the round rocker switch to fit.
      Is it for a customer or your amp? If it was me.. I would jumper it and use the amp. I doubt the Standby on a VS gets you much of anything really.
        We're gonna see if customer will go for a standard switch like found on Fender Red Knob Twin and go from there.
        Thanks,
        Jason
          Google Round Rocker Switch/ Images.
          https://www.google.com/search?q=roun...w=1360&bih=689
            Square Flange round rocker. Customer took what I had on hand and is satisfied.
            Thanks for suggestions,
            nosaj
