Results 1 to 6 of 6
Thread: Fender Bassman Ten - very low volume.
    Member PfeifferElectronics's Avatar
    Oct 2010
    TILLAMOOK, OR
    71
    Received: 2/0
    10
    A customer brought me a fender bassman ten from the late 70s. The complaint was hum after it warmed up. When I opened it up, it had all original components. So I proceeded to replace all the electrolytic caps and put two new 6L6 power tubes in it. Fired it up and it sounded great! So I proceeded to play for about 5 minutes, then volume dropped to nearly non-existent. BTW, the 6L6s are taking 60mA each which seems a little high but there is no bias pot. I checked the bias voltage to be -49V. Any ideas?
    VOLUME 4 U
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    16,429
    Received: 3,067/5
    Given: 3,705/0
    32
    Dirty contacts and/or pots?
    1 Not allowed! Not allowed!
    Old Timer
    Chill-Ville, VA
    3,455
    Received: 856/6
    Given: 1,762/10
    19
    Preamp tubes?
    So, what are the tubes actually dissipting? Did you check the bias supply components & replace those electrolytic caps? Humming after a warmup ALWAYS makes me suspect a bias supply problem first, because if it IS, it's likely the most expensive if not caught & fixed. If the tubes have redplated beforw, they may be permanemtly damaged and now grossly mismatched.
    It may not have a bias adjustmemt pot, but that doesn't mean it can't be adjusted.
    Justin
    May 2007
    pacific north west
    16,429
    Received: 3,067/5
    Given: 3,705/0
    32
    Here's the schematic.
    https://schematicheaven.net/fenderam...n_10_schem.pdf
    You sure don't need 60mA current for each tube. You should be able to increase the bias voltage by increasing the value of the 15k resistor off the balance pot. The schematic say's -59V (I think, it's pretty blurry). Even that might be low considering the higher modern wall voltages.
    Feb 2010
    12,606
    Received: 2,168/24
    Given: 5,470/11
    24
    Over-current tubes and loss of sound, I'd be looking for possible oscillation, or maybe output transformer issues.
    Oct 2010
    TILLAMOOK, OR
    71
    Received: 2/0
    10
    She's hummin now! I changed out the 15K resister on the balance pot to 20K. This got my bias current to 42mA. I need to do this anyway and I don't think this was the problem. However, by accident, while I was swapping that resistor out, I noticed the bass pot on the studio channel was very loose. I tightened it down to the chassis. Now everything is working great.
    2 Not allowed! Not allowed!
    VOLUME 4 U
  1. '68 Bassman amp volume
    By Doc Stitches in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-08-2017, 02:30 AM
  2. 1968 Fender Bassman- Serious Volume Loss
    By Lydian in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-21-2016, 01:56 AM
  3. Fender Bassman 70 Master Volume Pot?
    By Rhodesplyr in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-08-2012, 07:24 PM
  4. Problem with Fender Bassman SP3100 Volume Level
    By awillige4 in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-13-2011, 02:39 AM
  5. '59 Fender Bassman Reissue low volume
    By salperta in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-19-2010, 02:52 AM
Tags for this Thread
