Enzo,
the control grids (pin 5) do have some positive VDC on them, more on V4. Such VDC reading is somewhat unstable and changes between readings (maybe due to old solder joints). Thus new coupling caps are due.
One further step onward in the troubleshooting process...
I am going on with checking the other components (not too many after all).
I am pretty sure that new filter caps will cure the low B+ definitely.
Thanks for all the advice. I'll post an update as soon as I install the new filter caps.
