Results 1 to 9 of 9
Thread: Build = simple 50w tube Power amp.
    Feb 2007
    Iowa
    1,387
    Received: 11/0
    Given: 2/1
    14
    This might be a stupid idea.......
    Im thinking of building a simple 50 watt (2 el34) power amp to rackmount.
    Looking at a Marshall 2204 amp schematic...Id love to just make the power section of this.
    I just want to plug in any popular 1 ru rack preamp into it , like a Jmp-1 , or ADA , Fractal , Rocktron , or similar.
    SO....If i was to copy the 2204 output section , where exactly would my "input" be ?
    The Master volume pot ? Would that be an "Input Level " ? phase inverter tube would be first inline (PPIMV) ? or some extras in the front of the circuit ? I want to keep this simple as in no Op-amp / transistors .......
    i realize the power section would have less current draw due to no preamp section/tubes...
    Is there a schematic out there that is similar to what im talking about ? Theres a bunch of tube guitar style power amps out there..(Peavey Classic 60 / Marshall 9200) i just want to build a way more simple versionClick image for larger version.
    1 Not allowed! Not allowed!
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    31,626
    Received: 1,512/7
    54
    There are not usually line level points in the signal path of tube amps, unless you copy some amp from the return of an FX jack pair. Usual FX loop has a signal level drop to the send, then a boost back up to tube levels at the return.
    Amps don't get much simpler than a PV Classic 60. Power tubes, phase inverter tube, input buffer tube.
    Same with a Marshall 9005: two power tubes, phase inverter tube, buffer tube. They chose to do the phase splitting at low signal level THEN boost, but either way...
    Supporting Member
    Oct 2011
    Manchester, UK
    352
    Received: 26/0
    Given: 26/0
    8
    I know you want to avoid SS but the simplest way is to use an lnd150 input stage feeding the PI.
    Junior Member
    Feb 2019
    Italy
    7
    Received: 4/0
    Given: 4/0
    0
    Maybe take a look at the AX84 Project power amp:
    http://www.ax84.com/static/corepower..._Schematic.pdf
    Seems simple enough.
    Supporting Member
    Staffordshire UK
    3,653
    Received: 386/1
    Given: 375/1
    18
    That may not have sufficient voltage gain to make full power with the signal level available from some sources, eg delay pedal.
    Old Timer olddawg's Avatar
    Dec 2007
    La Jolla CA, Hanalei, Kauai
    2,935
    Received: 245/0
    Given: 29/1
    14
    I had a mil spec rack mount power amp years ago that was line level input. No volume control. Came out of a ship or something. 2x 6L6 push pull. Had the metal tubes. Went in the dumpster with a bunch of stuff in the early 80s. May be some literature on something similar if you look around.
    Feb 2007
    Iowa
    1,387
    Received: 11/0
    Given: 2/1
    14
    Quote Originally Posted by Fazer View Post
    Exactly what i was talking about--so will the output level of any popular preamp be perfect for this ( the input to the MV ) ?
    Junior Member
    Feb 2019
    Italy
    7
    Received: 4/0
    Given: 4/0
    0
    Quote Originally Posted by Valvehead View Post
    I think so. I use the one I build with a Madamp bass preamp kit, this one:
    http://www.madamp.de/index/lang/en/artikel/19
    I can't find my build notes with the voltages, but the Madamp schematic give a 1.2V RMS max output, so a line level output (or something less) should do.
    Aug 2012
    Great Black Swamp
    2,164
    Received: 357/0
    Given: 914/1
    9
    If 'any' preamp has a +4dBV output (which if my math is right, means just under 3.5vpp, same as Fazer's 1.2vrms) then that may not be enough to drive the 2xEL34 power stage pictured to clipping, given the NFB in circuit. Is that what you want, a clean-ish output stage?
    [I hate to suggest] Otherwise, add a recovery stage to the input of the power amp, and give yourself a true volume control instead of an attenuator.
  1. First build. Very simple, 3 watts, 6X4/6SJ7/6F6.
    By The Jonald in forum Build Your Amp
    Last Post: 01-18-2018, 03:43 AM
  2. Replies: 3
    Last Post: 07-11-2012, 04:05 AM
  3. Anyone ever build tube HiFi power amps?
    By wcrankshaw in forum Other Amps
    Last Post: 03-11-2011, 02:34 PM
  4. New 5E3 build power tube anomaly
    By jyoung in forum Tweed Builders
    Last Post: 07-11-2008, 01:59 PM
  5. Some simple scopes of my new build
    By MattT in forum Theory & Design
    Last Post: 11-08-2007, 12:50 PM
