I am wondering what sort of sealant you would use to hold a bias pot in place so it won't vibrate and change over time. I have read of using silicone, hot glue or even nail polish to do this. What would you use to just dab a bit to hold the shaft in place?
What do you use to hold a bias pot in place?
In cases where I can't use the Fender style CTS kind of panel mount pot, or don't want to drill extra holes in the chassis to fit one, I use what I call the "blue cube," a Bourns trimmer resistor. Here's the Mouser part # for the 10K version: 652-3386W-1-103LF . Regardless of the picture they show you, in this version there are 3 wire terminals out the side. It measures approx 1/2" square, or 1.2 cm for the rest of the world. Besides 10K, there are lots of choices for you. I keep a few 20K & 50K besides the regular 10K. A pea size dab of RTV holds the trimpot body in place. I've never had a problem with the adjustment walking off from where I set it.
Those trimpots like the Piher types you find in modern Fender Hot Rod Deluxe & similar, it looks like Fender schmears a wipe of pink nail polish on. Good enough for me. Go to the ladies' cosmetic section & pick your favorite color. I can't decide between plaid or paisley...This isn't the future I signed up for.
Originally posted by DrGonz78 View PostI got some hot pink color on hand!! I swear I don't use the stuff on a regular basis eitherThis isn't the future I signed up for.
Originally posted by DrGonz78 View PostAny specific color . Just kidding!!Originally posted by DrGonz78 View PostI got some hot pink color on hand!! I swear I don't use the stuff on a regular basis either
a) when I see it in an amp I know I was in there before.
b) a dab in a non-obvious spot on tools acts as a recognizable mark as tools tend to 'wander'.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by LeoIn cases where I can't use the Fender style CTS kind of panel mount pot, or don't want to drill extra holes in the chassis to fit one, I use what I call the "blue cube," a Bourns trimmer resistor...
If you want/need to use a panel mount potentiometer for a bias control (Which I use on the back panel of my amp), these offer a lot of security and flexibility in choosing parts.
https://www.alliedelec.com/product/a.../181/70927380/
These particular ones are manufactured by HH Smith/Abbatron, but I've seen other variants as well. The ones I currently use, I must have acquired in some bulk parts deal at some point. They work a little differently in that they are molded composite material which screws onto the bushing, exposing just the tip of a slotted shaft. It uses friction to prevent any the shaft from rotating.Last edited by SoulFetish; 03-26-2019, 11:40 PM.If I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
Originally posted by SoulFetish View PostThey work a little differently in that they are molded composite material which screws onto the bushing, exposing just the tip of a slotted shaft. It uses friction to prevent any the shaft from rotating.This isn't the future I signed up for.
Originally posted by Leo_Gnardo View PostWay back when I bought a box of Allen Bradley Ohmite pots, all sorts of values. Many had this locking feature, handy for bias adjustment. BUT none of them were values handy for amp biasing. Anybody need a 500 ohm locking pot, heavy duty mil spec? I got a box half full..."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostIs the shaft size inconsistent with other standard pots? I'm thinking you could just swap the mount and and collar nuts.This isn't the future I signed up for.
Interestingly, I just serviced an old Matamp Orange lead 200. All 4 KT88 had their own bias control via externally adjustable panel mounted bias pots. Each pot was fitted with this kind of locking sleeve. I'm not sure why Matamp didn't just purchase 20k potentiometers manufactured with locking bushings... maybe they couldn't source them readily in England at the time?If I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
Originally posted by Leo_Gnardo View PostOn the AB's the collar bushing is an integral part of the pot, so no swappage there. And ... swapping the resistor disc isn't an option either, like you can do on some standard pots like CTS.If I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
