Originally posted by Randall
View Post
Ampeg ET-2 tremolo will not work! Why?
Originally posted by Randall View PostDo you have any modulation at the plate of V5A?
Have you verified the speed and intensity pots are working?
Speed and Intensity pots are working. When intensity is on and tremolo is engaged there is distinct initial volume drop like it's turning on but then goes back to normal volume with no further modulation, likewise when intensity is all the way down and tremolo is engaged there is no volume drop. Speed pot checked resistance between lugs and is operational.
Any other suggestions?
Originally posted by Leo_Gnardo View PostOld Ampeg vibrato "bugs" are dying off at an alarming rate, as they are in aging Fenders. I've substituted my LED driven bugs for Ampeg's cube shaped bug, but it takes some fine tuning to make them work right. Unlike in Fenders, where the bug's photoresistor attenuates signal, in the Ampegs instead the blinking lamp allows the photoresistor to shunt across the vib depth pot (4 MegOhms ! ), passing signal with each blink. It takes only a very short pulse of current to allow this to work the way you want it to, so the resistor in series with the LED often winds up being a lot larger value than you might expect. Not having done one of these in a couple years I don't recall exactly. But around 2.2 Meg seems to ring a bell.
Originally posted by guildguy View PostI believe you maybe talking about a different circuit. Ampeg does not use LFOs, it is biasing tremolo.
There is no trem roach (or bug)
Of course it uses LFO's. Or an LFO as it were. Otherwise there's be no modulation. You recognized this in post #17 above. That triode is the oscillator. The low frequency oscillator. It seems to be engaging and conducting current when on, but not oscillating. Very hard to troubleshoot with just a tight shot of the components because it's impossible to see how they're wired to everything else. But there must be a problem with either how it's wired or any unexamined components related."Take two placebos, works twice as well." Enzo
