Anyone have a schematic for an Egnater Vengeance 120 head? I got denied by Egnater.
Blowing mains fuse. I’ve pulled all the tubes and have it plugged into a bulb limiter, and the bulb flickers for two seconds and then is really really bright once it settles. I was instructed to remove the PT secondaries to test the transformer but I’m not sure which wires are primary or secondary.
Originally posted by sunshine_bassman View PostBlowing mains fuse. I’ve pulled all the tubes and have it plugged into a bulb limiter, and the bulb flickers for two seconds and then is really really bright once it settles. I was instructed to remove the PT secondaries to test the transformer but I’m not sure which wires are primary or secondary.
