Results 1 to 7 of 7
Thread: Line out circuit help
  1. #1
    Supporting Member Randall's Avatar
    Join Date
    Jan 2013
    Location
    Cape Coral, FL
    Posts
    2,004
    Thumbs Up/Down
    Received: 232/0
    Given: 42/0
    Rep Power
    9
    I could use some help understanding how this particular line out circuit works on a Magnatone amp. (upper right, page two). I see it comes directly from the speaker out, so how is it reduced to a line level signal with just a 470 ohm resisitor? And I see the 47 ohm to ground, so if that is shunting much of the signal, wouldn't it drag down the speaker out signal as well?
    Mono Twilighter Schematic rev 2 20150617.pdf
    0 Not allowed! Not allowed!
  2. #2
    Supporting Member eschertron's Avatar
    Join Date
    Aug 2012
    Location
    Great Black Swamp
    Posts
    2,130
    Thumbs Up/Down
    Received: 332/0
    Given: 823/1
    Rep Power
    9
    It's shunting 470 + 47 Ohms to ground, so not much of a load. And yes, It's pretty basic. With a cap to drain off "some" high end, very little speaker emulation - a speaker emulator like in a SansAmp has 3 or 4 filters for a steeper slope.
    1 Not allowed! Not allowed!
  3. #3
    Supporting Member Jazz P Bass's Avatar
    Join Date
    Dec 2008
    Location
    Wernersville, PA
    Posts
    12,692
    Thumbs Up/Down
    Received: 363/2
    Given: 191/0
    Rep Power
    25
    Agree. The divider is not that much of a load.
    Looks like a divide by 10 for the line out.
  4. #4
    Lifetime Member Enzo's Avatar
    Join Date
    May 2006
    Location
    Lansing, Michigan, USA
    Posts
    31,538
    Thumbs Up/Down
    Received: 1,428/7
    Given: 0/0
    Rep Power
    54
    Classic voltage divider. 470 ohm over 47 ohms would work about the same as 1k over 100 ohms or 4.7k over 470 ohms.
  5. #5
    Old Timer J M Fahey's Avatar
    Join Date
    Oct 2007
    Location
    Buenos Aires, Argentina
    Posts
    11,211
    Thumbs Up/Down
    Received: 1,393/18
    Given: 1,057/27
    Rep Power
    26
    Whatīs that power amp output .... 20W into 4 ohms?
    So speaker voltage is around 9V RMS?
    Attenuate that 10X as mentioned above and you end up with 900mV RMS.
    Is that "Line level" enough for you?
    1nd 1uF + 47 ohms means a cutoff frequency of 3300 Hz at mere 6dB/octave.
    Very little, very weak, but better than nothing
    FWIW a Guitar speaker drops 24dB/oct , and simulators mentioned above do that.
    To avoid waking up my spiderweb covered calculator I use this useful page:
    http://www.sengpielaudio.com/calculator-RCpad.htm
    2 Not allowed! Not allowed!
  6. #6
    Bent Member Chuck H's Avatar
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    14,678
    Thumbs Up/Down
    Received: 1,713/4
    Given: 1,888/0
    Rep Power
    29
    Quote Originally Posted by Randall View Post
    Enzo and Juan pegged it. It's a voltage divider. Remember that the speaker output is of considerably lower voltage, but higher current than the voltage amplifiers in the signal chain. And then...
    Nope. With a speaker load measuring less than 20 ohms a parallel load of 470 ohms (the series resistor in the divider that is parallel to the speaker) is peanuts. For this reason the current through that particular circuit is insignificant. And as a result the line out circuit acts as a voltage dependent circuit parallel to the speaker, a current dependent circuit. The circuit relies on the input being fed as a high impedance. This prevents any significant current draw and keeps it a voltage relevant circuit. If the impedance of a fed input from this circuit were of a low impedance it would cause significant problems for the line out, but still have nearly no affect on the speaker output because the parallel load is still on the order of over 50:1 for an 8 ohm speaker load and over 100:1 for a 4 ohm speaker load.
    "Never bet your life on somebody else doing their job." SoulFetish's good friend
    "Being born on third base and thinking that you must have hit a triple is pure delusion!" Steve A
    "Back to the amp. It makes horrible sounds when I play my guitar thru it... because I suck at playing guitar." Mike6158
  7. #7
    Senior Member SoulFetish's Avatar
    Join Date
    Jan 2016
    Location
    Massachusetts
    Posts
    1,011
    Thumbs Up/Down
    Received: 287/1
    Given: 221/0
    Rep Power
    6
    Quote Originally Posted by J M Fahey View Post
    Holy sh*t, Juan. Look at all these audio calculations here
    http://www.sengpielaudio.com/Calculations03.htm
    That site's great! I bookmarked that page. Thanks for that
Thread Information
Users Browsing this Thread
  1. Voltage follower, buffer circuit , active circuit
    By cenizasblancas in forum Guitar Tech
    Last Post: 03-31-2013, 07:26 PM
  2. Line Level FET Push Pull circuit
    By Kirfew in forum Theory & Design
    Last Post: 04-28-2012, 03:24 PM
  3. Line 6 4X12 vs Line 6 4X12VS Help please
    By Zach in forum Guitar Amps
    Last Post: 02-26-2012, 04:41 PM
  4. Suggestions for Pro-Audio Line Splitter Circuit
    By dastuff in forum Guitar Effects
    Last Post: 07-18-2008, 10:53 PM
  5. Line-level attenuator circuit for recorder
    By Steve A. in forum Music Electronics
    Last Post: 03-13-2008, 02:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
