I have an 80's JC-120 on the bench- Channel 2 has no signal.
https://music-electronics-forum.com/...1&d=1208815304
Tracked down an issue at q5, a 2sk117, only getting about 2 volts instead of 15 for it's supply.
There IS a 15v supply- I measured it at r18, and again at the entry of q27 , but it seems like it lowers down to 2 volts at the exit of q27, an 2sd313 transistor.
2sd313:
B: 15v
C: 37v
E: 2v
Since there's SOME voltage coming out, should I assume something on the 15v rail is pulling it down to 2? Is there a better way to approach this problem?
Thanks as always.
2sd313:
B: 15v
C: 37v
E: 2v
Thanks as always.
