Results 1 to 9 of 9
Thread: DC Not Blocked in output stage. Why ?
    Member HaroldBrooks's Avatar
    Mar 2019
    113
    Received: 63/0
    Given: 301/0
    1
    Please bear with me, as I am relatively new to fixing tube amps, and still have some fairly big 'holes' in my understanding of electronics.
    That being said, I suddenly considered the fact that there are no coupling caps after power tubes, and the plate voltages go directly to the output transformer. I realize at that point there is no grid of the 'Next' stage to worry about, but why is it important to still have the DC current go to the output transformer ? How is this beneficial to the signal path and audio output ?
    I believe the output transformer is blocking the DC, and just letting the AC audio through ? Would it help or hurt to add coupling caps after a power tube (before the OP transformer), and if so, Why or why not either way ?
    I've never taken an electronics class, and it's something I seemed to have missed !
    (Embarrassing considering the work on amps I've engaged in so far, but I believe asking even very fundamental questions will pull me up the ladder)
    Thanks for your help !
    Aug 2012
    Great Black Swamp
    2,148
    Received: 346/0
    Given: 874/1
    9
    Think of it this way: the plate of the tube is not feeding the output transformer, but rather the output transformer is feeding the B+ to the tube. The output transformer (or half of it) replaces the plate resistor that you see in a preamp stage. No cap there, so no cap on the OT primary.
    The signal getting to the secondary of the OT is happy side effect of the power tube's changing conductivity (controlled by its grid), and changing the amount of current flowing through the OT. There's no current flowing from OT primary to secondary, if that's what you were thinking.
    As far as blocking DC through the tube itself, it would be hard (understatement) to bias the tube with no current. I'm not sure if that would work in class C or not?
    1 Not allowed! Not allowed!
    Mar 2018
    Germany
    1,537
    Received: 1,135/1
    Given: 693/2
    4
    Tube operation requires a load impedance to develop an output signal as well as a DC path for the plate current. In low signal signal stages both is accomplished by a plate resistor. But a plate resistor wastes a least half the available output power in dissipation. A transformer load is much more efficient (maybe 90%). Using coupling caps between output tubes and transformer is not necessary and would not allow for DC plate current without additional plate resistors wasting power.
    - Own Opinions Only -
    Mar 2019
    113
    Received: 63/0
    Given: 301/0
    1
    Fantastic, and thank you.
    I forgot that critical point of the output transformer is actually feeding the B+ to the power tubes ! It's right there on the schematic, but I keep ignoring it because the output transformer looks so small, and before I started fixing amps, I never realized the big voltage travels through that small transformer (only considered the power transformer as the Big Daddy), but it's burned into my brain now.
    Also as you stated, there is the resistance of the transformer replacing the plate resistor. Now I see how the AC will still pass through, and the output transformer acts as the 'Block' for the DC while supplying it in the first place, and regulating the voltage via it's natural resistance.
    Once again, thank you eschertron for setting me straight on this.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,278
    Received: 1,460/18
    Given: 1,116/27
    26
    Shorter answer: transformers do not pass DC, so there is nothing to block.
    Mar 2019
    113
    Received: 63/0
    Given: 301/0
    1
    Great, thank you for going further Helmholtz ! I won't forget the lesson regarding the output transformer's role now. No need for plate resistor or coupling cap I see, as it would waste signal energy and is not needed.
    Mar 2019
    113
    Received: 63/0
    Given: 301/0
    1
    Thank You JM Fahey !
    Dec 2008
    Wernersville, PA
    12,749
    Received: 408/2
    Given: 211/0
    25
    The 'True' role of the output transformer is to match the output tubes specified plate impedance to the speaker impedance.
    Roughly speaking you are looking at something like a 2K to 8 ratio.
    Here is a good but rather lengthy read:
    http://education.lenardaudio.com/en/...ve_amps_5.html
    Mar 2018
    Germany
    1,537
    Received: 1,135/1
    Given: 693/2
    4
    Yes, the OT provides the necessary DC path and steps up the the speaker impedance to a value that allows the tube deliver max. output power (800 Ohm to 2.5 K per tube for PP amps and up to 10k for single ended amps).
    It also isolates the speaker output from high voltages.
  1. Combining preamp stage with output stage
    By E biddy in forum Theory & Design
    Last Post: 05-14-2018, 06:39 AM
  2. fender stage 100 dsp severe hum in output stage
    By bassman 59 in forum Guitar Amps
    Last Post: 08-13-2015, 08:49 AM
  3. LTPI with CF stage---Fender Studio Bass Amp Output Stage
    By nevetslab in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-12-2014, 10:28 PM
  4. 'Tubelike' MOSFET output stage design idea - autotransformer output
    By Morris Slutsky in forum Theory & Design
    Last Post: 04-22-2010, 09:49 AM
  5. How many here blocked at LP forum?
    By Possum in forum Pickup Makers
    Last Post: 08-23-2008, 05:08 AM
