Results 1 to 9 of 9
Thread: Harmony H303A voltages/quiet amp
    Member Ampere's Avatar
    Nov 2015
    Finland
    22
    0
    Hi
    schematic:harmony_h303a_sch.pdf
    Having low output on this supposedly 8W amp. I'm suspecting the following.
    The plate voltage for the 12AU6 measures 18 VDC, which seems low. Datasheet suggests 250 or so. The "B" source is 118 VDC. R5 plate resistor is a little out of spec at 450K. C3 is not leaky. (disconnecting doesn't affect). I don't have another 12AU6 at hand, but the old one tested good on my Accurate Instruments 257 tester.
    The "A" voltage measured something over 120 VDC, which I assume is close to spec since the filter caps are rated 150V.
    The schematic has an error. R4 is connected to B source rather than ground.
    -Niko
    Dec 2008
    Wernersville, PA
    13,098
    Received: 624/3
    Given: 328/0
    28
    The plate voltage at the 12AU6 is definitely low.
    What voltage do you read at pin 6?
    Here is a similar (H400) schematic with voltage designations.
    (Although it is a "Widow Maker")
    harmony_h400.pdf
    Nov 2015
    Finland
    22
    0
    Sorry for the delay and thanks for the schematic.
    The voltage on pin 6 reads 22.4 VDC
    Dec 2008
    Wernersville, PA
    13,098
    Received: 624/3
    Given: 328/0
    28
    The only way forward is to try another tube.
    Nov 2015
    Finland
    22
    0
    Sorry for the long wait.
    I got a few NOS RCA 12AU6 and no luck. Ended up increasing the grid leak value to 10 Meg and got the plate voltage up to 30 V. Changed some caps and it sounds better. Still weird its not going any higher than that.
    Feb 2010
    12,612
    Received: 2,173/24
    Given: 5,479/11
    24
    Did you change C1 and C2 ?
    Supporting Member
    Mar 2018
    Germany
    3,203
    Received: 2,342/1
    Given: 1,334/2
    8
    A leaky C3 would hardly change V1 voltages. What about a leaky C1?
    1 Not allowed! Not allowed!
    - Own Opinions Only -
    Nov 2015
    Finland
    22
    0
    Yes, I tried disconnecting both C1 and C2. No change in DC voltages. IIRC disconnecting the C2 did lower the gain of V1.
    Feb 2010
    12,612
    Received: 2,173/24
    Given: 5,479/11
    24
    I would try replacing the plate resistor. It's already high, and may be going higher only when subjected to voltage.
  1. Harmony H303A mod
    By ratiug in forum Mods & Tweaks
    Last Post: 01-02-2012, 07:05 AM
  2. Harmony H303A amp
    By mtlbasslad in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-27-2010, 10:24 AM
  3. Dead Harmony h303a
    By 6ixstring in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-20-2010, 06:46 AM
  4. New 5e3 is Really Quiet
    By Kramer in forum Debugging Your Build
    Last Post: 08-13-2009, 11:00 PM
  5. Harmony h-304
    By hollisdevillo in forum Vintage Amps
    Last Post: 11-02-2008, 02:51 AM
Tags for this Thread
