Results 1 to 19 of 19
Thread: SCN Bridge Pickup faulty from the factory
    Junior Member
    Jun 2008
    10
    0
    Hello, can anyone give some advice or help on if it is possible to figure out & fix a brand new pickup, defective from the factory, instead of just throwing it away?
    (Fender won't replace it, or refund it, says it has been discontinued even though I purchased it new). They won't provide a diagram showing how the pickup is supposed look assembled, no wiring help, nothing
    (1) Bridge pickup, Fender SCN
    Actual measurements are:
    Inductance = 61.96H
    DC Resistance = 11.211k
    (12.165k Rp)
    Q = .231
    Per Manufacturer: it should be about 3.8 Henrys & 11.5K
    I cannot find anything on the internet explaining how these types of pickups are made, or exploded views.
    I am trying to find out what it means when a pickup measures 16 times more Henrys than it is supposed to. All the wires appear to be connected to various points on the pickup itself.
    Thanks.
    Jan 2009
    637
    Received: 21/0
    Given: 8/0
    11
    Which meter are you using to check it? DC resistance looks ok. What frequency do you have the meter set to ?
    Cheers
    Andrew
    Junior Member
    Jun 2008
    10
    0
    Hello Andrew, I am using a DE-5000 LCR meter using the 120hz setting.
    Thanks, GP
    Senior Member LtKojak's Avatar
    Feb 2008
    Milano, Italy
    1,012
    Received: 32/3
    13
    What exactly do you mean with "faulty from the factory"? Is it dead? If it is, the dealer you bought it from is responsible for the outcome. If it doesn't work, he is pretty much obligated to exchange it for another one, and and if he's not obligated to refund you, he's obligated to give you credit to purchase anything from the same value.
    1 Not allowed! Not allowed!
    Pepe aka Lt. Kojak
    Milano, Italy
    Dec 2008
    31
    Given: 3/0
    0
    Quote Originally Posted by One10 View Post
    search Bill Lawrence site, as he 'invented' the SCN's for Fender.
    Does the SCN's sound good beside 16 times more Henrys?
    Mar 2018
    Germany
    1,762
    Received: 1,329/1
    Given: 780/2
    4
    Must be a measuring error.
    There is no fault condition that could produce such increase of (real) inductance. Was the PU connected to a capacitor during measurement?
    http://zerocapcable.com/?page_id=210
    - Own Opinions Only -
    Supporting Member
    PDX
    3,273
    Received: 40/0
    Given: 21/0
    18
    Really the only things that can happen are a busted wire, a stretched wire, a cold solder joint, leads didn't get stripped or internal shorts in the coil. I suppose an easter bunny named "henry" could have been caught up in the winder and procreated for several generations.
    Junior Member
    Jun 2008
    10
    0
    Quote Originally Posted by LtKojak View Post
    It doesn't sound like a pickup should and works intermittently. Unfortunately they don't have to, but I will talk to them again about it. Thanks.
    Quote Originally Posted by dodona View Post
    No, it doesn't sound like a pickup, no highs and works intermittently. Bill sure was a genius at pickup design, wasn't he!
    No and no, it also is not a measuring 'error'.
    Quote Originally Posted by David King View Post
    One or more of those statements are probably true. Still would have liked to know how it is supposed to be wired up, in order to salvage it.
    It has been pretty hard to find just a bridge SCN pickup, it's a shame Fender did not at least offer to scrounge one up at their headquarters, even if it was used.
    1.) What is also odd, is that two of the pickups have all the pole pieces grounded, while the middle pickup has only the 'A' and 'B' pole pieces grounded, two out of six are grounded.
    2.) I also have not seen such poorly wound pickups before in a supposed 'quality' brand. One was wound so poorly, it was coming over the side of the top plate, or plates and the wires were kinked up from when the person pushed the pickup cover over the pickup (the windings did not fit in the prescribed area as designed). I had to gently push them back on to the side of the pickup and then glue them in place or they would have torn off completely when reattaching the pickup cover.
    Thanks for the quick replies everyone, I was delayed in my responses due to Uncle Sam getting my complete attention during the 14th. and 15th. of April.
    Mar 2018
    Germany
    1,762
    Received: 1,329/1
    Given: 780/2
    4
    There are PU fault conditions that change DCR, capacitance or decrease L. But I can't think of an effect that increases L by a factor of 4 other than doubling the turns number.
    By "measuring error" I included misinterpretation effects of the LCR meter. Try this : Measure a guitar cable in the L range between tip and sleeve. Your meter will probably show a high Henry reading. Of course this is wrong, it's a misinterpretation of the cable capacitance by the meter. I just tried it with a cable having a capacitance of 264pF. In L mode my meter reads 96 Henry though there is zero inductance.
    Apr 2013
    UK
    23
    Received: 9/0
    0
    I don't delve too deeply into testing pickups with LCR meters and the like, i prefer to do things by ear. Sounds like you're shorted to the ground. When you're getting 'no highs' it's just slightly touching, then no sound when it moves and makes good contact. That's the most common reason for the sound you've described.
    Mar 2018
    Germany
    1,762
    Received: 1,329/1
    Given: 780/2
    4
    Hard to imagine an intermittent problem that doesn't also change the DCR between the leads.
  12. #12
    Supporting Member
    PDX
    3,273
    Received: 40/0
    Given: 21/0
    18
    Could the small voltage that a meter puts out in a resistance test cause a poor connection to behave differently?
  13. #13
    Mar 2018
    Germany
    1,762
    Received: 1,329/1
    Given: 780/2
    4
    I don't think so, especially as meter test voltages (several hundred mV) are similar to PU peak voltages.
  14. #14
    Junior Member
    Jun 2008
    10
    0
    Ok Mr. Helmholtz, I have done that and these are the measurements:
    A.) Cable has a capacitance of 345pF.
    B.) Tip and sleeve measurement reads 5.179 Henrys in the mode setting as you requested.
    GP
  15. #15
    Junior Member
    Jun 2008
    10
    0
    Quote Originally Posted by jop120 View Post
    ok jop120. Could be as you say. I suppose I will keep looking for another bridge SCN pickup as I would lose too much money just getting rid of the other two.
    Thanks.
  16. #16
    Apr 2013
    UK
    23
    Received: 9/0
    0
    Before ditching it, you could do some simple practical tests, it could take as little as a piece of tape to fix.
    Take off the cover and expose as much of the pickup as possible(if you can get to the coil tape remove carefully) . Have a good look around and see if you can see a sort somewhere. If no luck, then connect it directly to a jack and plug it into an amp (not too loud), with one hand tap the pickup with a small screwdriver to hear a signal, while doing that have a good poke around all over the pickup and try to find a point where it's breaking or making the short.
    You might have no luck, but you might find a simple short that can be cleaned or insulated. Worth a go.
  17. #17
    Junior Member
    Jun 2008
    10
    0
    I have a look at it, I'll need to find a better magnifying glass first at a hobby shop. They are not wrapped in any tape, just bare coils.
    GP
  18. #18
    Junior Member
    Apr 2019
    9
    Received: 5/0
    Given: 1/0
    0
    Apologies if this is a double post (Or if I accidentally sent someone a message), I'm new to the forum.
    I recently had an SCN apart and found these drawings from Bill very helpful.
    http://www.billlawrence.com/Pages/Al...tm/Patent2.htm
    2 Not allowed! Not allowed!
  19. #19
    Junior Member
    Jun 2008
    10
    0
    Thank you, Gonzo id.
  1. Telecaster Bridge Pickup Baseplate - A New Look
    By Mr McRuff in forum Pickup Makers
    Last Post: 08-09-2016, 03:36 AM
  2. Bridge Pickup Too Bright
    By jrdamien in forum Beginner/ Hobbyist
    Last Post: 02-11-2015, 05:04 PM
  3. supro in bridge pickup
    By johnnydr in forum Pickup Makers
    Last Post: 02-24-2013, 07:51 PM
  4. New Travis Bean Bridge Pickup. Quadcoils pickup?
    By Tooth Of Davinci in forum Pickup Makers
    Last Post: 09-06-2012, 04:38 PM
  5. Least mid heavy bridge pickup
    By RoadToNever in forum Guitar Tech
    Last Post: 09-25-2010, 01:57 AM
