champ amp low output
  • champ amp low output
    Working on a champ with low output. With 150mv input what typical levels should be seen at the preamp outputs and the output of the power tube at the plate. Im new to tube amps. Any help would be appreciated.
Name:	5F1 Schematic.jpg
    If you don't know where your going any road'll take you there : George Harrison
      I don't see output levels from the tubes unless I am missing something.
        https://www.thetubestore.com/lib/the...atic-Rev-B.pdf
          Alexradium///Thanks for the reply, that's what I'm looking for.
            my apologies , glad alexradium was able to help, good luck !!
              Thanks for the replies. Up and running
