Is this coil split wiring correct?
  • Is this coil split wiring correct?
    Can somebody please tell me if this wiring diagram is correct for my intentions?
    I want the following configuration:
    2 x Single Coils [Red Cable Hot, Green Cable Ground]
    1 x Humbucker [Red Cable Hot (North Start), Violet Cable (North Finish + South Finish = Two Middle Cables), Green Cable (South Start), Silver (Bare Ground Cable)]
    All green + silver cables are ground cables, blue + red cables are simple connections. I only used different colors to make it easier to interpret.
    The 5 way switch should lead to the following pickup constellations:
    Position 1: Bridge Humbucker
    Position 2: Bridge Humbucker + Mid Single Coil
    Position 3: Mid Single Coil
    Position 4: Mid Single Coil + Neck Single Coil
    Position 5: Neck Single Coil
    The push/push tone knob should split the humbucker, so that I only use a single coil of the humbucker in positions 1 and 2. If the Mid Pickup is RWRP, can I get noise cancellation that way in position 4 and 2 (if the humbucker is split)?
    Here's my diagram:
    BTW: Can I use the housing of the DPDT push/push switch, which is atop of the tone knob, for grounding or should I use the side of the pot?
