Results 1 to 9 of 9
Thread: Old 63 Bandmaster seems alittle ill
    Aug 2006
    453
    Received: 14/0
    Given: 51/0
    14
    My amp was sounding OK on Wed But,today I turn it on and it didn't sound right Harsh not the normal sweet tone..I turned the bright switch on and off and it was making a loud pop, not the normal pop.I changed out all the tubes and it helped a little but I still get Loud Pop on both the Normal and the Vibro chanel Is there a easy check I can do brfore going all through grid plate test..
    Jan 2011
    NorCal
    485
    Received: 105/10
    Given: 118/0
    10
    Visual inspection of caps in doghouse, B+ dropping resistors and screen/grid resistors. How old are the caps?
    http://amps.monkeymatic.com
    Aug 2006
    453
    Received: 14/0
    Given: 51/0
    14
    Quote Originally Posted by xtian View Post
    Did a full recap 7 yrs ago It was fine when I played the other day Is it normal to have a loud Pop when I turn on the Bright switch,also there is a small amount scratchiness on the normal channel volume from 6 to 10 could that coupling cap be starting to go Would both the normal and Vibrato volumes be scratchy..I need to strart at my guitar check cables too..Trying to get some ideas before I open up the hood
    Sep 2011
    Pace, FL
    3,630
    Received: 1,317/102
    Given: 183/36
    12
    Quote Originally Posted by dumbassbob View Post
    Scratchiness can also be a dirty pot. Try working the pot back and forth . Use your multimeter on the normal vol channel to see if there is DC there then I might suspect cap.
    nosaj
    Aug 2006
    453
    Received: 14/0
    Given: 51/0
    14
    Quote Originally Posted by nosaj View Post
    nosaj
    I am not real good at tech stuff I play guitar I don't fix them lol But do I put the test leads across the 1 and 3 lugs or the 1-2 lugs with the volume off what am I looking for with volume off there should be No DC voltage on the pot I do have a VTVM but I have never really used it,If I undo the coupling cap to grid it should have zero volts?
    Supporting Member Randall's Avatar
    Jan 2013
    Cape Coral, FL
    2,651
    Received: 639/0
    Given: 113/0
    10
    Would you like to buy some punctuation?
    Black lead to chassis, red lead to pot lugs.
    Sep 2011
    Pace, FL
    3,630
    Received: 1,317/102
    Given: 183/36
    12
    Quote Originally Posted by Randall View Post
    Yes, Vanna I would like a .
    nosaj
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    16,434
    Received: 3,069/5
    Given: 3,709/0
    32
    And don't check for DC on the wiper with the pot at zero. Turn the pot all the way up and check at either un grounded lug.
    You should be able to check for a leaky capacitor in circuit. If there's DC such that it's affecting circuit operation you should be able to see it with a meter. If the circuit is such that the downstream end of the coupling cap is also the grid of the following tube then you should check with that tube out of the circuit.
    1 Not allowed! Not allowed!
    Aug 2006
    453
    Received: 14/0
    Given: 51/0
    14
    Thanks Chuck I overreacedt to soon,I put 3 worn out RCA 12ax7 in I didn't look close. They still work in the Vibrato curcuit,Also most of my cables jacks are showing bare copper on the tips,and a few 6100 frets are flating out,I need to recrown(I play a lot) and I messed with the dark circuit on my old Telecaster,and the setscrews are worn and they slide down a touch the control plate,,The 63 BM seems ok no voltage on pot
  1. Bandmaster 4 Ohm OT into 8 cab?
    By shocki in forum Theory & Design
    Last Post: 09-29-2012, 02:06 AM
  2. Fender bandmaster
    By jarrod624 in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-08-2011, 09:27 PM
  3. Fender Bandmaster
    By gbono in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-01-2011, 09:46 PM
  4. 67-68 Bandmaster
    By plaush in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-12-2010, 02:29 PM
  5. 67 Bandmaster cap job
    By sgfable in forum Repair and Restoration
    Last Post: 09-10-2009, 06:17 PM
