Results 1 to 8 of 8
Thread: 70's Schecter Pickup Info
    Sep 2011
    Minneapolis
    293
    Given: 1/0
    8
    I've got a 70's or 80's Schecter single coil in for repair (from whatever guitar/s had the metal pickguards). 3 pickup configuration like a Strat. All pickups are the same polarity and have the same yellow/left black/right leads.
    Any ideas if these were reverse wound or what size wire was being used?
    The other two pickups read 10.45k in the neck and 11.16 in the bridge.
    The owner wants this as close to original as possible and I don't want to dig in unless I have some more info.
    Thanks!
    Junior Member
    Apr 2013
    UK
    18
    Received: 8/0
    0
    If all coils have the same have the same magnetic polarity and have yellow/left - black/right lead wires, then they are all wound the same way, so the blended positions are two singles as a pose to an RWRP parallel pair.
    considering the DCR you've measured from the other two pickups and the size of the coils, they're pretty likely wound with 43AWG. Looking at the coil wire wrapped around the flatwork it's wound with poly wire, couldn't tell you if is single build or double build. You could try to measure the existing wire with a micrometer, to determine the build of the coating, just be super careful not to squash the wire.
    As for wind count, I'd guess and wind it up, then measure, adjust as necessary, cut off and then rewind again to get it close. When you first strip the original wire off, have a look at how it's been wound, how tight/loose the wire is and how much scattering, cause that makes a massive difference in fender-ish single coils.
    Senior Member LtKojak's Avatar
    Feb 2008
    Milano, Italy
    1,001
    Received: 28/3
    13
    My word of advice would be the following: Double-build Formvar wire, AWG#43 gauge, 95TPL, 9,000 turns. I couldn't find if it's wound CW or CCW, so that's for you to assess.
    HTH,
    Pepe aka Lt. Kojak
    Milano, Italy
    Sep 2011
    Minneapolis
    293
    Given: 1/0
    8
    Kojak -
    Thanks on that. It may not be double formvar (I have yet to unwrap it) but it'd have to be 43. Maybe even 10k winds.
    Looks like clockwise to me but I had to remove the wax dripped over the ends and grommets to verify which isn't something I can do with the others so I have to guess they are all CW.
    Schecter, not surprisingly, has no info at all.
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    11,161
    Received: 743/32
    Given: 722/14
    21
    If the black is the start wire, then it would be CCW. (right arm, top going)
    If the yellow is the start wire, then it would be opposite.
    Maybe you can tell which side is start and finish?
    T
    It's only Rock and Roll, but I like it!
    Sep 2011
    Minneapolis
    293
    Given: 1/0
    8
    Black is the start and so the top would be going, which means the bobbin is spinning CW, no?
    Jun 2010
    Mid-South USA
    11,161
    Received: 743/32
    Given: 722/14
    21
    I guess that is by each perspective.
    1 Not allowed! Not allowed!
    Sep 2011
    Minneapolis
    293
    Given: 1/0
    8
    Quote Originally Posted by big_teee View Post
    Haha, no, you're correct. I was sleepy.
  1. Schecter Hellraiser Stage 100 2x12 Transformers
    By stevenrb718 in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-30-2018, 04:19 AM
  2. Info On This Vox Pickup
    By jrdamien in forum Pickup Makers
    Last Post: 10-24-2017, 10:39 PM
  3. Schecter Hellwin amp
    By lowell in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-04-2017, 06:24 AM
  4. Taped Schecter Strat Singlecoils ?
    By Electricdaveyboy in forum Pickup Makers
    Last Post: 10-30-2009, 11:19 PM
  5. Sherwood pickup info needed....
    By Possum in forum Pickup Makers
    Last Post: 05-10-2008, 01:35 PM
