Results 1 to 8 of 8
Thread: Tektronix preamplifier
    Oct 2015
    NEPA
    839
    Received: 196/1
    Given: 136/0
    5
    Tektronix type 122 preamplifier. Picked this up at the local flea market along with some tubed medical equipment. Recapped the power supply and it works. Going to use for guitar, or a conversation piece anyway. It's a differential amp so it works if i ground one side of the input. I made a simple pnp phase splitter (filaments are -6vdc so i used that) for input to the preamp. Here are my 3 questions, the 10meg resistors on the V1 (12ax7) input, very high, should i reduce to 1meg so the tube doesn't run away? V2 (12au7)also has 4.7 meg, should i drop that too? Also, what cap should i use for the output? I have a 10uf soldered there now because it was on the bench. Will a 0.1uf be ok? And yeah, i can get 15vrms out of it, i think the spec was 20mv for full output.Click image for larger version.
    Oct 2015
    NEPA
    839
    Received: 196/1
    Given: 136/0
    5
    Replying to my own thread. Since there is a negative voltage on the cathode, these are set up as grid leak bias? So, the high value resistors are needed. I think anyway. Data sheet for 12ax7 and 12au7 shows 10meg when cathode is at 0.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    32,453
    Received: 2,009/7
    55
    Drop it so tube doesn't run away? Wha??? I doubt the Tektronix folks had a problem with runaway 12AX7s.
    If you plan to turn it into a guitar amp, then change whatever you like.
    Supporting Member nevetslab's Avatar
    Apr 2010
    Burbank, CA
    1,839
    Received: 665/1
    Given: 1,506/1
    11
    This is very similar to the Type E Plug-in that serviced the 530 & 540 series scopes of that era. I've hung onto my Type 132 Power Supply, which allows me to use any Letter Series or 1-series plugins from those scopes. The 132 supply allows differential output, while the 131 supply, accepting the same plug-ins, only yields single-ended outputs. Those early plug-ins are a thing of beauty in construction, and lend themselves nicely to mods for audio use. The Type E has a lot more gain available than the 122. I also have one of the coveted blank plug-ins for that series so when the desire motivates me, I can build what I want into that plug-in and have it for use in the 132 Power Supply. These plugins sell for peanuts, and have for years, as the demand has long since dropped off. But, are a great place to start for building a nice preamp.
    Among the vintage plugins I've kept are: 1A7, 1A5, Type W & Type E...all differential single channel circuits. The 1A7 was the first all-solid-state high gain differential plugin that has been packaged as the front end of 5030 & 5031 dual beam scopes (10uV thru 10V/Div), 7A22, 5A22, AM502A (TM 500 series plugin), and on into the 11000 series plugins. The 1A5 and Type W have a DC offset generator to allow DC coupling at high gain in the presence of high voltage. The Type E had a sensitivity of 50uV/Div in those early scopes, with the same LF/HF response filters (single-pole rolloff).
    1 Not allowed! Not allowed!
    Oct 2015
    NEPA
    839
    Received: 196/1
    Given: 136/0
    5
    This was part of the deal also, very sharp trace compared to other scopes.
    Apr 2010
    Burbank, CA
    1,839
    Received: 665/1
    Given: 1,506/1
    11
    5000 series scope. I don't recall those particular vertical amp plugins, though recognize the time base plugin. BGW Systems had bought a number of 5000 series scopes in the late 70's, though that model (don't recall which) never did have a sharp CRT trace. This one you picked up looks far sharper.
    Apr 2010
    Burbank, CA
    1,839
    Received: 665/1
    Given: 1,506/1
    11
    Vintage Tektronix Letter & 1-series plugins & Power Supply for Preamp projects?
    I was able to pull up some images on the Letter Series Plugins from Tektronix, along with the service manual on the Type E Differential Plugin, which is very similar to your Type 122.
Name:	Tek Type E Plug-in-1.jpg
ID:	53386 Click image for larger version.
Name:	Tek Type E Plug-in-3.jpg
ID:	53387 Click image for larger version.
Name:	Tek Type E Plug-in-4.jpg
ID:	53388 Click image for larger version.
Name:	Type 132 with Type O Operational Amp Plugin.jpg
ID:	53389 Click image for larger version.
ID:	53390 Click image for larger version.
ID:	53391Click image for larger version.
    Type E.pdf
    I forgot about the Type O Dual Differential Plug-in shown installed in the Type 132 Power Supply. I also picked one of those up over the years, waiting for one of those periods of time to turn it into something. If memory serves, it's an all-tube design.
    Oct 2015
    NEPA
    839
    Received: 196/1
    Given: 136/0
    5
    Yes, the trace is very sharp. Plug ins 5a24n, 5a24n, 5b10n. Just sold a B&K and need to get rid of a few more but the 5103 was part of a haul. I could always leave it in the garage for a backup to my backup. Going to a hamfest this week so I hope more plugins don't follow me home Except maybe a spectrum snalyzer. I have a 2465a and a 2430 I need to recap but keep putting that project off, wonder why.
  1. Replies: 0
    Last Post: 02-09-2017, 09:40 AM
  2. EF86 preamplifier suggestions
    By Giaime in forum Theory & Design
    Last Post: 06-12-2010, 03:22 PM
  3. New to Electronics and Aiming to build a Microphone Preamplifier
    By Douglasfur in forum Music Electronics
    Last Post: 04-17-2009, 03:14 AM
  4. Tektronix 464 or 465?
    By Satamax in forum Music Electronics
    Last Post: 02-18-2009, 07:42 AM
  5. Harman Kardan Galaxy Mixer preamplifier advice
    By marktokach in forum Music Electronics
    Last Post: 02-20-2008, 07:27 AM
