Results 1 to 11 of 11
Thread: Thought this was interesting no OT
  1. #1
    Master Destroyer nosaj's Avatar
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    2,795
    Thumbs Up/Down
    Received: 816/100
    Given: 113/33
    Rep Power
    10
    2 Not allowed! Not allowed!
    Binkie McFartnuggets‏:If we really wanted to know the meaning of life we would have fed Stephen Hawking shrooms a long time ago.
  2. #2
    Supporting Member mozz's Avatar
    Join Date
    Oct 2015
    Location
    NEPA
    Posts
    764
    Thumbs Up/Down
    Received: 149/1
    Given: 109/0
    Rep Power
    4
    Does OTL have any sort of damping factor?
    1 Not allowed! Not allowed!
  3. #3
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    2,795
    Thumbs Up/Down
    Received: 816/100
    Given: 113/33
    Rep Power
    10
    Quote Originally Posted by mozz View Post
    That's above my paygrade, I'd never heard of OTL so was just putting it out there.
    nosaj
    0 Not allowed! Not allowed!
  4. #4
    Join Date
    Feb 2010
    Location
    Posts
    11,204
    Thumbs Up/Down
    Received: 1,163/21
    Given: 2,934/8
    Rep Power
    22
    Only do-able with high impedance speakers. The ones I'm aware of were 600ohm Philips. Rare and expensive.
    Just because they don't have tubes doesn't mean they don't have feelings! - glebert
  5. #5
    Join Date
    Oct 2015
    Location
    NEPA
    Posts
    764
    Thumbs Up/Down
    Received: 149/1
    Given: 109/0
    Rep Power
    4
    There are some tubes(with enough of them) you can use with regular speakers(8ohm 16 ohm), 6as7?
  6. #6
    Join Date
    Feb 2010
    Location
    Posts
    11,204
    Thumbs Up/Down
    Received: 1,163/21
    Given: 2,934/8
    Rep Power
    22
    Yes, if you use enough of them you can probably do it with any tube. But you may end up with an amp that looks like EINIAC.
    3 Not allowed! Not allowed!
  7. #7
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    2,795
    Thumbs Up/Down
    Received: 816/100
    Given: 113/33
    Rep Power
    10
    Quote Originally Posted by g1 View Post
    Just imagine the PT.
    nosaj
  8. #8
    Supporting Member eschertron's Avatar
    Join Date
    Aug 2012
    Location
    Great Black Swamp
    Posts
    2,129
    Thumbs Up/Down
    Received: 332/0
    Given: 815/1
    Rep Power
    9
    Quote Originally Posted by nosaj View Post
    nosaj
    Run the heaters off the line. 19 x 6.3 = about 120vac.
    just kidding.
  9. #9
    Supporting Member
    Join Date
    Mar 2017
    Location
    Massachusetts, USA
    Posts
    1,292
    Thumbs Up/Down
    Received: 122/0
    Given: 1,920/0
    Rep Power
    4
    Ooo, that sounds like a build challenge!
    Colonel Potter:
    "You're askin' a man who graduated 246 out of a class of 248 to do his BEST?"
  10. #10
    Lifetime Member
    Join Date
    May 2006
    Posts
    4,391
    Thumbs Up/Down
    Received: 342/1
    Given: 3/0
    Rep Power
    21
    The circuit shown is a self-split push-pull circuit. It was invented to get an active cathode follower "push pull" output to get lower output impedance from a tube stage as well as high gain. It was a variant of the "mu-amp".
    Historical notes:
    OTL was the Holy Grail of amp makers back in the days when tube amplifier design was all there was. The high fidelity industry recognized that the OT was a big limiting factor in getting to lower distortion. The OT itself contributed distortion and limited bandwidth. At the same time, it contributed so much phase shift that amps could not remain stable while having enough gain and feedback to feedback-out the distortions.
    So the high fidelity world flirted a lot with how to get rid of the OT. the big limiter was, as noted, the low currents possible with practical setups of tubes. This was attacked with high impedance speakers and barely-possible arrays of tubes. High impedance speakers traded higher output voltages for lower current, which helped the low-current tubes swing them, but high impedance speakers have lots of turns of fine wire, high internal capacitance, leakage fields and nonlinearities of their own.
    The electrostatic speaker movement was one attempt to use high voltage, low current tube outputs directly, to eliminate the OT. Unfortunately, electrostatic speakers need voltages in the thousand volt range and so they tend to need step UP transformers to drive them well. Sigh.
  11. #11
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    1,361
    Thumbs Up/Down
    Received: 968/1
    Given: 637/2
    Rep Power
    4
    The circuit is also known as SRPP (Shunt Regulated Push Pull):
    https://www.tubecad.com/may2000/index.html
    http://www.valvewizard.co.uk/SRPP_Blencowe.pdf
Thread Information
Users Browsing this Thread
  1. And I thought I was bad...
    By Enzo in forum Music Electronics
    Last Post: 06-28-2015, 04:04 PM
  2. Thought for the day...
    By blearyeyes in forum Music Electronics
    Last Post: 06-25-2013, 11:15 PM
  3. 67 bassman thought
    By mtx11 in forum Theory & Design
    Last Post: 02-23-2009, 03:51 AM
  4. This may be some Jello for thought.
    By BlackAdder in forum Theory & Design
    Last Post: 02-18-2008, 02:09 AM
  5. a little thought on potting
    By dpm in forum Pickup Makers
    Last Post: 12-03-2007, 12:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
