Thought this was interesting no OT
Only do-able with high impedance speakers. The ones I'm aware of were 600ohm Philips. Rare and expensive.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Yes, if you use enough of them you can probably do it with any tube. But you may end up with an amp that looks like EINIAC.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by nosaj View PostJust imagine the PT.
nosaj
just kidding.If it still won't get loud enough, it's probably broken. - Steve Conner
Originally posted by g1 View PostYes, if you use enough of them you can probably do it with any tube. But you may end up with an amp that looks like EINIAC.The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
The circuit shown is a self-split push-pull circuit. It was invented to get an active cathode follower "push pull" output to get lower output impedance from a tube stage as well as high gain. It was a variant of the "mu-amp".
Historical notes:
OTL was the Holy Grail of amp makers back in the days when tube amplifier design was all there was. The high fidelity industry recognized that the OT was a big limiting factor in getting to lower distortion. The OT itself contributed distortion and limited bandwidth. At the same time, it contributed so much phase shift that amps could not remain stable while having enough gain and feedback to feedback-out the distortions.
So the high fidelity world flirted a lot with how to get rid of the OT. the big limiter was, as noted, the low currents possible with practical setups of tubes. This was attacked with high impedance speakers and barely-possible arrays of tubes. High impedance speakers traded higher output voltages for lower current, which helped the low-current tubes swing them, but high impedance speakers have lots of turns of fine wire, high internal capacitance, leakage fields and nonlinearities of their own.
The electrostatic speaker movement was one attempt to use high voltage, low current tube outputs directly, to eliminate the OT. Unfortunately, electrostatic speakers need voltages in the thousand volt range and so they tend to need step UP transformers to drive them well. Sigh.Amazing!! Who would ever have guessed that someone who villified the evil rich people would begin happily accepting their millions in speaking fees!
The circuit is also known as SRPP (Shunt Regulated Push Pull):
https://www.tubecad.com/may2000/index.html
http://www.valvewizard.co.uk/SRPP_Blencowe.pdf- Own Opinions Only -
