Results 1 to 15 of 15
Thread: New winder changed the tone
    Member GunbarrelCustom's Avatar
    Jun 2013
    58
    Received: 3/0
    7
    Iíd like any help I can get with this....
    My old winder died and I picked up a shiny new one! Much faster, but maybe thatís the issue. The pickups Iíve made on the new machine seem darker and less lively. Could faster winding speed be changing the final product?
    I did change my potting mixture to a lower percentage of beeswax though I donít think itís had much of an effect. I had always watched for bubbles and it seems like they are too heavily potted and lack that alive nature so I am going to go by time on the next couple to see if that is part of it.
    Thanks in advance.
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    11,826
    Received: 1,090/32
    Given: 1,040/14
    22
    Just a guess here, but did you get new wire?
    Sounds like new smaller diameter wire, per gauge?
    Also, if you are winding faster, are you winding looser?
    On HB Pickups, I like to Pot the whole pickup after assembly.
    Tht gives the coils minimum potting, but quietens the whole overall pickup.
    Please let us know what you come up with!
    GL,
    T
    **If you have any ideas, please jump in?
    "If Wishes Were Horses, Beggars Would Ride!" Scottish Proverb 1600s
    Jun 2013
    58
    Received: 3/0
    7
    Actually itís the same old wire.
    I did recharge the magnets and that helped a lot! Itís like the heat of the potting is demagnetizing the pickups slightly. Iíve been winding Tele bridge pickups to get used to the new machine. It just sucks to change pickups with the traditional bridge. Is Alni3 more susceptible to degaussing by heat? I know the originals can seem like there is no magnetism!
    If anything I think Iím winding tighter due to the higher speed pulling it tight and maybe too tight and Iím stretching the wire from 42 or 43 to 42.5 & 43.5 dulling the sound. It seems worse with Plane Enamel and I prefer modern poly for tone as scatter winding tames the ice pick highs. My next step is to wind one slower to see how that affects the results.
    Iíve only done one humbucker, for a Keef tribute Tele, and didnít pot it. I used A3 to match the bridge and it works very well. I just canít get that true PAF tone and response that the $400 a set guys can hit. I may try a degaussed A5 shiny magnet to brighten up the tone. I wired it with two volume pots and no tone so each pickup sees the correct pot value and the 11.5k ohm bridge doesnít need a tone control sucking high end.
    Iím also concerned about the value of the pots as the Mojo pots are seldom at the rated value or above. CTS quality has really slipped since 2012 when I built my first guitars. Just wish there were other choices for vintage taper, easy turn pots. Has anyone used the plastic bodied Bournes pots?
    1 Not allowed! Not allowed!
    Jun 2010
    Mid-South USA
    11,826
    Received: 1,090/32
    Given: 1,040/14
    22
    I've noticed the demagnetizing with heat.
    On the tight or loose coils with higher speed?
    I think that would depend on your tensioning device, and method.
    Like You said, you may be stretching the wire.
    T
    Woodgrinder/Pickupwinder copperheadroads's Avatar
    Jun 2009
    Iceburg Alley ,Newfoundland,CAN
    2,173
    Received: 50/1
    Given: 49/0
    13
    If your stretching the wire you will see higher dcr reading .
    Feb 2015
    161
    Received: 77/0
    Given: 8/0
    6
    are you hand guiding? The machine spins faster are you traversing faster or at the same speed you use to?
    Jun 2013
    58
    Received: 3/0
    7
    Yes straight hand winding. Iím trying to scatter less to add highs, especially with humbuckers though Iím not noticing added highs but more honky mids.
    My earlier pickups definitely have more magnetic strength and wonder if the rare earth magnets Iím using to charge the pickups have lost strength? Or maybe I got A5 instead of A3 early on as Iím using a different supplier. Could A3 vary the gauss it can hold from different suppliers?
    Member jack briggs's Avatar
    Oct 2007
    Raleigh
    275
    Received: 3/0
    Given: 19/0
    13
    Quote Originally Posted by GunbarrelCustom View Post
    I’m trying to scatter less to add highs
    Huh?
    Jun 2010
    Mid-South USA
    11,826
    Received: 1,090/32
    Given: 1,040/14
    22
    My earlier pickups definitely have more magnetic strength and wonder if the rare earth magnets I’m using to charge the pickups have lost strength?
    It's difficult to get a consistent charge in alnico bar magnets with short NEO magnts.
    If you run the neo down the edge of the longer bar magnet, you can end up with more charge on one end.
    Make sure you are getting a consistent charge on the whole bar.
    I agree that less scatter, makes a smaller diameter coil, and that IME make's it a little brighter.
    T
    Supporting Member
    Mar 2018
    Germany
    3,222
    Received: 2,352/1
    Given: 1,337/2
    8
    I can't think of a reason why a smaller diameter coil should sound brighter. The aperture doesn't depend on coil dimensions, it is determined by the magnetic field.
    - Own Opinions Only -
    Old Timer
    Boston, MA area
    2,666
    Received: 26/0
    18
    The height (perpendicular to core) to width (along the core) ratio can affect self-capacitance.
  12. #12
    Supporting Member
    Mar 2018
    Germany
    3,222
    Received: 2,352/1
    Given: 1,337/2
    8
    Yes, generally a tighter wound coil will have somewhat higher self-capacitance. From what I have seen, I expect the differences for a given bobbin and turns number to lie within 30..50pF. On the other hand a slimmer, denser wound coil has less inductance, which counteracts the increased capacitance.
    I think the sonic changes will be marginal.
    A much stronger effect would be produced by a difference of 10% in turns number.
  13. #13
    Old Timer
    Boston, MA area
    2,666
    Received: 26/0
    18
    The issue was the shape of the coil, not the winding density (that being an independent issue).
    People do claim to be able to hear the difference.
  14. #14
    Supporting Member
    Mar 2018
    Germany
    3,222
    Received: 2,352/1
    Given: 1,337/2
    8
    My remarks were in the context of the OP's question, where only the winder was changed. Everything else (coilformer, wire type, number of turns..) I assumed to stay unchanged.
  15. #15
    Jun 2013
    58
    Received: 3/0
    7
    Iíve done some like usual which where I traverse along to music. Iíve done a few where Iím trying to get what I think a machine might do and only scatter every few hundred turns. I donít like the latter because they are less lively (microphonic) and I didnít get the increased highs I was expecting.
    One thing I realized Iíd changed was I have been potting at a much higher temperature than before and I think Iím getting too much wax in the coil. I donít want squeal, but I like pickups that ring out if the body is thumped.
  1. Bias radically changed by itself
    By daz in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-08-2017, 09:21 AM
  2. why fender changed polarity on strats?
    By Rosewood in forum Pickup Makers
    Last Post: 10-28-2007, 05:09 AM
  3. how do you know when tubes need changed
    By 60 second crush in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-05-2007, 07:43 AM
