Results 1 to 2 of 2
Thread: Coil split and phase wiring
    Twobie
    May 2019
    4
    0
    Hi guys I'm having some issues with the wiring on my prs mira... Been over at the seymour duncan forum but literally cannot get a straight answer... Just jargon and things I don't quite understand what they're trying to say... I'll just copy my post here:
    Had some mods done on my prs mira and had two Duncans fitted... I asked for coil split on the tone and phase switch on the volume. By the looks of it the neck pickup taps to the slug coil and the bridge to the screw coil... I'm not particularly happy with the splits and just wondering what needs to be changed so that the neck will split to the screw coil and the bridge to the slug coil
    Just to clarify the red and white from both pickups are going to the coil tap on the tone and the green and black from the bridge are going to the phase switch on the volume
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    11,821
    Received: 1,089/32
    Given: 1,039/14
    22
    Not familiar with the Mira, pictures of the control cavity would help.
    It would all need to be rewired to change which coils are selected.
    You would need to wire one coil inside out (bridge), and the neck outside in.
    If I was wiring it, I would forget about the phase switch wiring to start with, until I had the split figured out and working.
    A wiring diagram you can mark up will also help you figure it out.
    Another simple option, is to turn the pickups around in the pickup rings.
    GL,
    T
    "If Wishes Were Horses, Beggars Would Ride!" Scottish Proverb 1600s
  1. Is this coil split wiring correct?
    By jfsonic67 in forum Guitar Tech
    Last Post: 04-17-2019, 09:35 PM
  2. Replies: 2
    Last Post: 10-13-2012, 01:52 AM
  3. Replies: 3
    Last Post: 05-05-2010, 07:02 PM
  4. HH split coil Strat wiring (diagram included)
    By mspunk13 in forum Guitar Tech
    Last Post: 03-30-2010, 07:14 PM
  5. Wiring for coil split with vintage wire
    By kevinT in forum Pickup Makers
    Last Post: 05-22-2008, 04:02 AM
