Behringer B205D no noise
  • Behringer B205D no noise
    Hallo,
    i'm from Germany and my english is not so good. Please excuse me.
    I have a Behringer B205D that makes no noise when it is switched on. The powerlight is on, the phantomlight can switched on. The schematic i have downloaded.
    The +15 and -15V and the 48V are ok. I can touch the Preamp-Board where i want, no noise is comming out. It is like the Box is switched off.
    During my searches suddenly it was working, then again not.
    Who can help me please?
    I have made some more Tests directly at the IC's of the Pre-Amp. At all of them the +15 and -15V and also the 48V are available. Then i took a amplified PC-Speeker an plugged it to the Thru-Plug. That is working. Music was comming out of the PC-Speaker. So the Pre-Amp is ok.
    But there is no noise from the b205d-Speaker. The PWR-Amp is not working.
      Something strange!
      After the measurements i assembled the pre-amp and build it in. Then i tested again the pass-thru. It was working. Then i plugged in a mikrofon and suddenly the B205D-Box was working on all inputs. Then i increased the main-volume. At a high level suddenly the pwr-amp was switching off.
      Is there a overload protection?
        Heureka, i found the problem
        It was so banal!!!
        A bad contakt at the loudspeaker!!!
          Glad you solved it
          Please upload the schematic here to help others in the future.
          Thanks.
