Have this amp in my shop, checked and measured all of the components in that circuit and most of the board, all within spec, put in new 12at7's and total retube, no change. Photo-optic bug changing with speed control. where else do I need to look?
'72 Fender super reverb no trem
Do you mean the light is changing with speed? If so, that tells us everything up to that point is working, but doesn't tell us if the other side of the bug is working. I'd try hitting the eyelets on that side, I have fixed more than one this way. Also, put your meter across those two legs, do they change resistance with speed control? They should. If not, bad bug.It's weird, because it WAS working fine.....
