New Valco Output Transformer - 6V6 Push Pull - National 1224
  • New Valco Output Transformer - 6V6 Push Pull - National 1224
    Recently purchased a National (Valco) push pull 6V6 amp and the twin 6" x 11" oval speakers. The speakers have seen better days ; They still work but by the sound of it, they are very worn and have a tiny bit of coil rub just starting.
    I want to use the 6" x 9" Vintage 47 speakers that are available as a retrofit for Valco amps using those oval Rolas. The Rola speakers are 4 ohms and run in parallel so you end up with a 2 ohm output transformer as an original.
    Here are the speakers :
    http://www.vintage47amps.com/V47-Speakers/
    To make matters worse though, the stock output transformer is riveted to one of the original speakers, and I am hesitant on drilling it out the original rivets to reuse the output transformer with the new 4 ohm speakers. Running the new speakers in parallel is ok (2 ohms), but I was thinking about using another transformer all together and fully preserve the original speakers and transformer.
    Perhaps an 8 ohm output transformer, and just run the new vintage 47 speakers in series to get 8 ohms.
    Question : Would this transformer be a good choice ? http://www.classictone.net/40-18063.pdf
    If not any other suggestions would be greatly appreciated.
    I tried running a single Jensen C12R reissue with this amp, and it sounds far too bright compared to the original oval Rola speakers, and I am hoping the Vintage 47 speakers are what the say they are, that is modeled after the original Rolas.
    There is also a problem with shoe horning a decent 10" or 12" speaker into the existing tight combo cabinet. The power transformer is smack in the middle of the chassis and hangs down interfering with a single speaker magnet, hence the need to have the amp stay a twin so the two speaker magnets will clear the transformer.
    Thanks for your help !!!
    Why not have the originals reconed? Have you called Weber? If they won’t do it they could probably recommend someone. I know the kits exist. Probably cost less than the replacements.
      I will call Weber, but I've never seen a recone kit after quite an extensive search and heard of many owner in my same boat.
      The 6" x 11" Rola is an odd one, and the only thing I've found even close is a Grundig speaker, and those are original ancient 1950's speakers, just like the Rolas with no other peers.
      Thanks though for putting the idea in my head, and I will definitely call Weber to see if they can help, but somehow I don't think they can based on what I've found out so far.
      If they can't help with a recone, I am left using the Vintage 47 speakers and another new output transformer.
        I vote for recone. I use speakersaver.com here in Florida. Carl does nice work. Also, it should be said that the maker of Classic Tone, Magnetic Components, was the supplier for Valco transformers for a period, and they are making them from the original spec sheets.
          I would like to have the original speakers re-coned very much, and would pay a premium to have that done, but it doesn't look like anyone has those cones, or the facility to fix the voice coils. The speakers work, but I believe the voice coils have seen better days.
          They are an 'off' size, approx. 7" x 11" (Not 6" x 9"). I've seen ancient Telefunken and one other German speaker in that size, but no new ones, and no re-cone kits. For some reason the Rola ovals were abandoned, and I an not sure why considering the large amount of amps Valco sold with those speakers in the 1950's and just touching on the early 60's.
          I will give them a call, but I amp doubtful going in...
          Thank you very much for your help Randall, in any event !
            Weber do a 6 x 9 and they probably have recone parts for these (although nothing listed on their website). Email Brian Spane at Weber (their speaker parts guy).
