Results 1 to 20 of 20
Thread: Loud hum 100Hz
  1. #1
    Junior Member
    Join Date
    Jun 2019
    Location
    Belgium, Europe
    Posts
    8
    Thumbs Up/Down
    Received: 5/0
    Given: 3/0
    Rep Power
    0
    Loud hum 100Hz
    Hi, first time poster here, and actually had to search the difference in size between Neptune and Jupiter.
    So, I have this Engl Fireball 60 (e625) from the second hand market which is emitting a loud (like real loud) 100Hz hum. There is some guitar sound coming through however it's very bad sounding.
    I made a short video so you'd have an idea what's going on:
    https://photos.app.goo.gl/pYgBEjWKJXsxcsor9
    I swapped all preamp/power tubes for new ones and tried the fxloop send to another poweramp, the hum is still there but far less noticable, and the signal is ok.
    The fireball is diode rectified, and since the hum frequency is 100Hz I suppose there's no problem there.
    I ordered some new filtercaps, but I doubt the problem lays there, I did a little charge/discharge test with a MM, and when the amp is in service, there is 380volts over them.
    So I'm not sure what to do next. Ground loop perhaps?
    The scheme of the fireball:
    https://el34world.com/charts/Schemat...l_fireball.pdf
    Cheers
    0 Not allowed! Not allowed!
  2. #2
    Stray Cap DrGonz78's Avatar
    Join Date
    Oct 2011
    Location
    Scottsdale, AZ
    Posts
    2,113
    Blog Entries
    1
    Thumbs Up/Down
    Received: 316/5
    Given: 208/0
    Rep Power
    10
    Well if it is 100hz hum I would check for AC ripple, suggesting a leaky mains filter cap. I would think a ground loop would be a 50hz hum. In the US we have different mains voltage so it is 120hz DC hum and 60hz AC hum.
    2 Not allowed! Not allowed!
  3. #3
    Junior Member
    Join Date
    Jun 2019
    Location
    Belgium, Europe
    Posts
    8
    Thumbs Up/Down
    Received: 5/0
    Given: 3/0
    Rep Power
    0
    Quote Originally Posted by DrGonz78 View Post
    Thanks, yes you're right about the 50hz ground loop. You mind sharing how and where I can measure AC ripple? I know a thing or two about electricity in general, but my amp expertise is zero. Also, I just have a digital multimeter here.
  4. #4
    Join Date
    Nov 2013
    Posts
    285
    Thumbs Up/Down
    Received: 113/11
    Given: 36/0
    Rep Power
    6
    i suggest to change all filter caps anyway,they were not so good back then and they are already old,plus you don't want to change them one at a time in a pcb board made like that.
    Shotgun method,its not very expensive and will last much more,buy F&T.
    1 Not allowed! Not allowed!
  5. #5
    Supporting Member Jazz P Bass's Avatar
    Join Date
    Dec 2008
    Location
    Wernersville, PA
    Posts
    12,885
    Thumbs Up/Down
    Received: 491/3
    Given: 260/0
    Rep Power
    26
    "You mind sharing how and where I can measure AC ripple".
    You have already demonstrated that you can safely measure the DC voltage on the power supply nodes.
    So do the same except set your meter to read Volts AC.
  6. #6
    Junior Member
    Join Date
    Jun 2019
    Location
    Belgium, Europe
    Posts
    8
    Thumbs Up/Down
    Received: 5/0
    Given: 3/0
    Rep Power
    0
    Ok, so measuring AC voltage over the filtercaps? And it should read 0, if not they are faulty, is that correct?
  7. #7
    Join Date
    Jan 2011
    Location
    NorCal
    Posts
    388
    Thumbs Up/Down
    Received: 53/10
    Given: 68/0
    Rep Power
    9
    Hi. We're having this same conversation over at TGP with the OP, BTW, FYI.
    No, AC ripple at the reservoir (first) filter cap will not be zero--you can expect up to 10vAC and still have normal operation.
  8. #8
    Junior Member
    Join Date
    Jun 2019
    Location
    Belgium, Europe
    Posts
    8
    Thumbs Up/Down
    Received: 5/0
    Given: 3/0
    Rep Power
    0
    Quote Originally Posted by xtian View Post
    Hi. We're having this same conversation over at TAG with the OP, BTW, FYI.
    No, AC ripple at the reservoir (first) filter cap will not be zero--you can expect up to 10vDC and still have normal operation.
    You meant to say 10vAC?
    Thanks for elaborating on this forum too.
  9. #9
    Senior Member Pedro Vecino's Avatar
    Join Date
    Jul 2006
    Location
    Spain
    Posts
    662
    Thumbs Up/Down
    Received: 198/2
    Given: 97/0
    Rep Power
    14
    Quote Originally Posted by InDecember View Post
    I ordered some new filtercaps, but I doubt the problem lays there, I did a little charge/discharge test with a MM, and when the amp is in service, there is 280volt over them.
    I dīont know if I have understood it well, but the voltage in the first and second filter capacitor should be between 425 and 440 volts approximately.
    Visually check if some of the surface mounted* ones have any brown crystallized trace on the positive terminal.
    (*) In other models two of them are mounted on the underside of the board.
  10. #10
    Junior Member
    Join Date
    Jun 2019
    Location
    Belgium, Europe
    Posts
    8
    Thumbs Up/Down
    Received: 5/0
    Given: 3/0
    Rep Power
    0
    Quote Originally Posted by Pedro Vecino View Post
    Visually check if some of the surface mounted ones have any brown crystallized trace on the positive terminal.
    Oh sorry, that's a typo. I measured 380v not 280.
  11. #11
    Join Date
    Jan 2011
    Location
    NorCal
    Posts
    388
    Thumbs Up/Down
    Received: 53/10
    Given: 68/0
    Rep Power
    9
    Yes, AC.
  12. #12
    Old Timer J M Fahey's Avatar
    Join Date
    Oct 2007
    Location
    Buenos Aires, Argentina
    Posts
    11,753
    Thumbs Up/Down
    Received: 1,877/23
    Given: 1,463/35
    Rep Power
    27
    I would troubleshoot a little before random replacing parts.
    1) I see power tubes glow bright purple when you switch amp ON, suspect some nasty LED illuminating them.
    Checked schematic and there they are :LD2 and LD3 . Oh well.
    Which makes me suspect your video shows the amp in the full tilt Ultra Gain mode.
    a) link/upload the User manual, this amplifier is funky.
    b) set amp to "normal", not "Ultra", all controls on zero, test and upload video.
    I want to check whether hum responds to controls or not
    c) pull Phase Inverter V4 and repeat tests ... any change in hum/buzz?
    Please post results before proceeding further.
  13. #13
    Junior Member
    Join Date
    Jun 2019
    Location
    Belgium, Europe
    Posts
    8
    Thumbs Up/Down
    Received: 5/0
    Given: 3/0
    Rep Power
    0
    Hi, yes the powertubes are illuminated by 2 leds. (They illuminate when power is on, its independent of channelchoice).
    I must say I did test it on both channels (clean and ultra gain) and there is no difference in the intensity or volume of the hum. Gain control (or any other) isnt affecting it either. I also tested with pulling v3 v4 v5 and v6 and again no change. The only thing that makes the hum even louder is increasing one of the 2 master volumes (I just went a quarter of the way up, don't dare to go higher).
    A link to the manual:
    https://englamps.de/wp-content/uploa...5_Fireball.pdf
  14. #14
    Junior Member
    Join Date
    Jun 2019
    Location
    Belgium, Europe
    Posts
    8
    Thumbs Up/Down
    Received: 5/0
    Given: 3/0
    Rep Power
    0
    Ok so I'm measuring 800 ACvolts over the first filtercap. I'm sure I'm doing something wrong here, or is this an indicator the cap went bad?
  15. #15
    Join Date
    Jun 2006
    Location
    Norristown state hospital
    Posts
    2,260
    Thumbs Up/Down
    Received: 155/4
    Given: 1/0
    Rep Power
    16
    Probably.
    Had a Fender Deluxe Reverb reissue with a bad filter cap yesterday.
    Symptoms are as you mentioned: hum, lower DC voltage than normal and over 100volts AC at first filter node.
    Your filter is probably bad.
  16. #16
    Old Timer olddawg's Avatar
    Join Date
    Dec 2007
    Location
    La Jolla CA, Hanalei, Kauai
    Posts
    2,964
    Thumbs Up/Down
    Received: 276/0
    Given: 30/1
    Rep Power
    14
    A picture of the board would be nice. Frequently the filter cap leads become disconnected from the pads on the board after years of vibration. I would resolder everything in the power supply area first. A floating filter cap displays the same symptoms as a bad one.
  17. #17
    Join Date
    Feb 2010
    Location
    Posts
    11,627
    Thumbs Up/Down
    Received: 1,535/23
    Given: 3,905/11
    Rep Power
    22
    I think your meter can not measure AC when DC is present (inexpensive meters often can't). You would need a cap in series with the positive probe, something like a .1uF 600V.
    But I also agree with the others that the main filter cap is probably bad. The DC voltage is too low like Pedro said, even 380V there is too low.
    Just because they don't have tubes doesn't mean they don't have feelings! - glebert
  18. #18
    Join Date
    Oct 2007
    Location
    Posts
    11,753
    Thumbs Up/Down
    Received: 1,877/23
    Given: 1,463/35
    Rep Power
    27
    Like G1 said, your meter can not measure AC if mixed with DC so you can not measure ripple (you still can measure mains and transformer windings though)
    So "800VAC" means nothing in this case.
    Please repeate 2 tests:
    1)
    2) with V4 pulled, measure VDC at +V , which is the positive end of the first filter cap.
    I am guessing itīs open/unsoldered/pad or track cracked/"it is not there", but guesses are checked by measurements.
    Hint: if a cap is open, a meter set to DC reads about the RMS voltage fed there by the transformer while if the cap is doing its duty it will read about the peak voltage.
    The second is about 1.4 times the first.
  19. #19
    Junior Member
    Join Date
    Jun 2019
    Location
    Belgium, Europe
    Posts
    8
    Thumbs Up/Down
    Received: 5/0
    Given: 3/0
    Rep Power
    0
    The new filtercaps came in today, I installed them and the hum is gone. This was prolly a standard repairjob so sorry if I made it look like a massive problem, it's because of my lack of knowledge of these amps. Anyway, I learned alot, things to keep in mind for the next time, thx for helping me troubleshoot guys. Cheers
    5 Not allowed! Not allowed!
  20. #20
    Join Date
    Oct 2007
    Location
    Posts
    11,753
    Thumbs Up/Down
    Received: 1,877/23
    Given: 1,463/35
    Rep Power
    27
    Cool.
    So you were straight missing your first power filter.
    That explains both the massive (unfiltered) hum and the 30% lower "DC Voltage" ... although it was not real DC but unfiltered full wave rectified AC ... not the same.
Thread Information
Users Browsing this Thread
  1. Mesa Subway Blues some hum/buzz 100Hz, out of ideas
    By iefes in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-25-2018, 09:01 AM
  2. 100Hz Hum diagnosis
    By ColinMac in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-11-2015, 01:49 PM
  3. Loud hum
    By txstrat in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-18-2009, 09:13 PM
  4. Why does adjusting 100Hz on EQ affect high E string
    By clintonb in forum Theory & Design
    Last Post: 03-10-2009, 03:41 PM
  5. Loud Pop
    By RONNIE B in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-26-2007, 11:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
