Bassman build finally completed!
  • Bassman build finally completed!
    I started on this almost two years ago. As the story goes, a young man without a clue was trying to sell around town a badly abused 68 Bassman head, and a music store he tried to hawk it to gave him my number. He wanted $200 for it, but it was badly rusted, heavily and poorlly modded, and the head cab was chock full of carpenter ants. I told him I'd give him $100, and that was a risk, not knowing if the transformers were good or bad. He declined and left. About a week later, he changed his mind and I bought it for $100, although I immediately wished I had offered less.
    Turns out all the trannies tested good, so I proceded to tear it down. I stripped the chassis and tranny covers to bare metal and painted. I cleaned as much rust as I dared from the laminates, and sealed with lacquer. I made new boards from grey fiber (which after time does have some conductiveness, but without any real symptoms), and used what blue mallory caps I could. I used F&T filter caps, Sprague cathode caps, Mallory 150 and silver mica tone caps, and 1 watt carbon film resistors on the board, and 2 watt metal film in the PS. I put in new sockets, jacks, pots and switches. Cleaned up the brass plate real good, put in mid controls at the back where two jacks had been added, installed a Hi/Lo power switch where the ground switch was located, and a push/pull on one of the volume controls as a channel jumper switch. I wired it as a AB165, but with AB763 style bias circuit, and the first channel having a 5F6-A tone stack, no deep switch, and bright switches on both sides.
    It has a Fender branded Eminence 4 ohm 100 watt speaker, and GT branded Russian 5881WXT power tubes. This was my first tolex and grille cloth jobs as well.
    I did not do the cabinetry, I supervised a friend. He used 3/4" finger jointed pine for the cabinet, and 5/8" cabinet grade baltic birch ply for the baffle.
    In the end, I am quite pleased with it. This amp does not sound like any Fender I have ever played, it barks like a dog, very crunchy, but with nice articulation. It is a nice size and weight, and it's LOUD. Thanks fellows for the advice on the tweed tone stack (nice touch), and the channel jumpering. I got the switch idea from Rob Robinette's site.
    Here are some photos of the process:
ID:	874649Click image for larger version
ID:	874650Click image for larger version
ID:	874651Click image for larger version
ID:	874652Click image for larger version
ID:	874653Click image for larger version
Name:	main bd 001.JPG
ID:	874654Click image for larger version
ID:	874655Click image for larger version
Name:	Bassman build.jpg
ID:	874656Click image for larger version
ID:	874657Click image for larger version
ID:	874658Click image for larger version
ID:	874659Click image for larger version
ID:	874660Click image for larger version
ID:	874661Click image for larger version
ID:	874662Click image for larger version
ID:	874663Click image for larger version
    Awesome Job Randall.!!!!
    nosaj
      Nice work!
      Man that was bad!
      I love seeing projects like this.
      If it ain't broke I'll fix it until it is...
      I have just enough knowledge to be dangerous...
        SWEET!!! Do us all a solid and find the best guitar player you have at your disposal to play for a video clip Would love to hear it. It sounds like it would be simultaneously unique and familiar. A player that knows how to get the most out of an amp could really exploit it's character. I want to hear it. Hell of an effort and I'm sure well worth it. Nice job.
          Thanks Chuck, I'll see what I can do about the video. Kind of a politically sensitive area with my guitar player friends, but I'll try. How do you even make a loud video that doesn't sound crappy anyway?
            One mic set about 1/2" inside of the speaker edge angled toward the center just as close as you can get without distorting the mic. Another mic set at the furthest point in the room. Blend them, or don't But between the two one, both or a blend will work.
              You can get a pretty accurate recording (within reason) with an iPhone 10ft away.
                If you still have it wired as an AB165 topology with that 3rd "gain" stage w. negative local feedback, that might explain the bark. That's something no other Fender before or since came with besides the AB165 & later 50W Bassman heads. The AB165 has some "wonky" stuff that didn't last, & that might be why so many people trash them as sounding bad... But if you put a gun to my head & said I could only choose one amp of mine to keep- it'd be my AB165.
                Excellent work, & I'm glad someone else out there likes the AB165.
                Edit: question! Is that the original spec OT? Is there any indication it came with a different one? It looks huge compared to the PT. Reason I ask is, mine is the same way. I looked into the Fender part numbers & found out mine crosses to a Twin Reverb OT; I then found a couple of the mounting holes on mine are off a fraction of an inch. Sure enough, I've got a matching loose TR OT at home with the same Fender part number. If so, that might also explain some of rhat bark.
                Justin
                  Excellent piece man! Very nicely done!
                  Is there a thread that I can read to get up to speed on the build details (ideas that might have been tossed around etc) that helped this come to fruition?
                  (Love the documentary pictorial BTW!)
                  Start simple...then go deep!
                  "EL84's are the bitches of guitar amp design." Chuck H
                  "How could they know back in 1980-whatever that there'd come a time when it was easier to find the wreck of the Titanic than find another SAD1024?" -Mark Hammer
                    "Is there a thread that I can read to get up to speed on the build details (ideas that might have been tossed around etc) that helped this come to fruition?"
                    This is how it started: https://music-electronics-forum.com/...hlight=bassman
                      Awesome job, Randall! I'd love to hear it, too.
                        [ATTACH=CONFIG]53897[/ATTACH]
                        What does the Low/Hi Mode Switch do?
                        EXCELLENT RE-BUILD JOB!!
                          You set it according to your mood. The lo mode sounds better for minor chords.
                            I was guessing it's a pentode/triode switch.
                              +1. Removing the death cap provides a hole in just the right spot to jump the screens. And the switch can be re-purposed, so no parts to buy!
