Results 1 to 10 of 10
Thread: JBL EON 615 no audio output
  1. #1
    Junior Member
    Join Date
    Apr 2018
    Location
    South africa
    Posts
    7
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Rep Power
    0
    Hi
    Currently I'm facing a weird issue on my Eon 615. The unit starts up, signal indicator is active but no sound comes out. I've replaced the entire input board assembly with a known working one the results did not change. I've replaced the Power amp/smps board and the unit gives sound. So I went back to the faulty board replaced the 2 TDA8954th Ics and theres still no audio.
    Any help will be greatly appreciated..
    0 Not allowed! Not allowed!
  2. #2
    Supporting Member The Dude's Avatar
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    6,373
    Thumbs Up/Down
    Received: 1,260/1
    Given: 975/1
    Rep Power
    16
    Have you checked the speakers? If the power amp failed and output DC voltage to the speakers, it's possible the speakers burned open.
    “Yeah, well, you know, that’s just, like, your opinion, man.”
  3. #3
    Junior Member
    Join Date
    Apr 2018
    Location
    South africa
    Posts
    7
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Rep Power
    0
    Speakers are fine. I've tried another power amp/ smps board(both are incorporated into 1 pcb)and sound passes thru. Theres something on that smps board that caused the amplifier circuit to mute
  4. #4
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    6,373
    Thumbs Up/Down
    Received: 1,260/1
    Given: 975/1
    Rep Power
    16
    Have you tried a factory reset? It could just be corrupt settings.
  5. #5
    Junior Member
    Join Date
    Apr 2018
    Location
    South africa
    Posts
    7
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Rep Power
    0
    Yes I have done a factory reset. I can confirm it is a powersupply fault as 1000uf 50v capacitors were swelled(I replaced them already)
  6. #6
    Supporting Member Jazz P Bass's Avatar
    Join Date
    Dec 2008
    Location
    Wernersville, PA
    Posts
    12,940
    Thumbs Up/Down
    Received: 534/3
    Given: 289/0
    Rep Power
    26
    There are markings on the power board for the HV rails.
    +35/ -35Vdc I think.
    Are both voltages good?
    Power Board PCB part #: Assembly JBL 5054674
  7. #7
    Junior Member
    Join Date
    Apr 2018
    Location
    South africa
    Posts
    7
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Rep Power
    0
    Yup. The voltages are there. For some reason the TDA8954TH is stuck on mute..usually on a working speaker you would hear a very low audible hiss with no input signal. In this case I'm not getting that. I do get a very very very low pop noise on switch on which is normal on these Eons. Other than that I'm still very confused.
  8. #8
    Junior Member
    Join Date
    Apr 2018
    Location
    South africa
    Posts
    7
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Rep Power
    0
    It's not the input pcb as I've tried a working one.
  9. #9
    Join Date
    Dec 2008
    Location
    Wernersville, PA
    Posts
    12,940
    Thumbs Up/Down
    Received: 534/3
    Given: 289/0
    Rep Power
    26
    The Mode pin has to be greater than 4.2Vdc for the amp output to operate.
    Kind of hard to get at the ic but what voltage is on the pin?
    TDA8954_Pinout.pdf
    TDA8954_ Mute.pdf
  10. #10
    Junior Member
    Join Date
    Apr 2018
    Location
    South africa
    Posts
    7
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Rep Power
    0
    I cannot do any measurements now as the power supply is completely dead on the secondary stage. Could a power surge cause this type of failure. The initial fault was no sound output and now a new fault arises
Thread Information
Users Browsing this Thread
  1. C-Audio RA500
    By muschl in forum Schematic Requests
    Last Post: 02-28-2017, 05:39 AM
  2. audio testing of amplifiers...espically home audio and PA...
    By bsco in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-05-2015, 12:19 PM
  3. M-Audio Cx8 Schematic?
    By WashedUpRockStar in forum Schematic Requests
    Last Post: 05-04-2012, 10:39 PM
  4. Avs Audio Editor
    By MattyTheGuitarist in forum Fun with computers
    Last Post: 02-22-2009, 12:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
