Help with Pmh2000
  • Help with Pmh2000
    Hello I am repairing a Pmh2000, and after having replaced all the transistor of the power plate, and check diodes, resistors of the power part I still have 65 volts in one of the outputs, I also lack the voltage of +15, the of -15 if it is. The ICs 4580 and 3080 are damaged, because they are connected to +15 ?. Could you tell me where to go? Many thanks
    For a start, carefully examine the schematics, compare the measured voltages with the schematic and replace the defective components.
    PMH2000 schematic is located here:
    https://music-electronics-forum.com/showthread.php?t=41121
    It's All Over Now
      More direct link to the schematic: https://music-electronics-forum.com/...6&d=1560185842
        Repair your power supplies before deciding ICs are bad. They cannot possibly work with one of their power supplies missing.
        The whole circuit cannot work without proper power supply. I can say that about ANY powered circuit.
        You can remove the 3080 and the amp should still work. Just a test.
          In the scheme 3080, would be the Lm3080?
            I am sorry, I was being casual, and I shouldn't.
            Yes, the 3080 means the LM3080. It is used as a compressor, and if removed, the amp still works but loses the compressing function. That is it will no longer prevent clipping if over driven.
