Results 1 to 11 of 11
Thread: Convert 1x12" 8 ohm to 16 ohm guitar speaker
    New Member
    Jun 2019
    2
    0
    I'm considering to convert a 1x12" 8 ohm guitar speaker cabinet to match my 16 ohm amp. I will buy a new 12" 16 ohm speaker to fit in the cab. Would I have to replace the wiring of the speaker output as well? Or could I simply fit the new speaker in?
    This is the speaker I'm looking to buy:
    https://www.gear4music.com/us/en/Gui...r-Cabinet/2Q9A
    Supporting Member
    Staffordshire UK
    3,766
    Received: 513/1
    Given: 468/2
    18
    Wow thatís cheap!
    The existing wiring should be fine, just swap in another speaker. Careful when removing the female spade connectors, you donít want to force things and have them open up, thereby losing grip in future. There may be locking tabs on the spades to latch them in place / prevent them being pulled off accidentally; so they may need prying open with a small flat screwdriver.
    Regarding your amp, maybe it has an unused 8 ohm output on the output transformer?
    1 Not allowed! Not allowed!
    New Member
    Jun 2019
    2
    0
    Thanks for the tips. It's dirt cheap indeed. Even if you throw away the speaker and just use it for the cab.
    The amp is a Marshall DSL1CR, it only has one 16 ohm output.
    Supporting Member
    Staffordshire UK
    3,766
    Received: 513/1
    Given: 468/2
    18
    It's worth giving the OT a close examination, there may be an unused 8 ohm wire or terminal available.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,753
    Received: 1,880/23
    Given: 1,463/35
    27
    Irt definitely might, so itīs worth checking.
    That said, I guess today_not_so_popular 16 ohm choice by Marshall (an d some Laney and Vox amps, all "British" *may* be to push users to get some 16 ohm Marshall cabinet or at least a Celestion 16 ohm speaker.
    Old Timer olddawg's Avatar
    Dec 2007
    La Jolla CA, Hanalei, Kauai
    2,977
    Received: 287/0
    Given: 30/1
    14
    Just curious as to why you are doing this? An 8 ohm load on a 16 ohm tap is no different than having a 16 ohm main speaker and a 16 ohm extension cab. A one level mismatch is common. I doubt that using an 8 ohm speaker on a 16 ohm tap will cause any problems. Itís done all of the time.
    Feb 2010
    11,742
    Received: 1,607/23
    Given: 4,114/11
    22
    Quote Originally Posted by olddawg View Post
    In this case (DSL1) they don't offer any ext. jacks (head or combo) and specifically warn about possible OT failure if used with loads below 16 ohms. They don't seem that confident about it, and I'd suspect they would void warranties over the issue if someone were to admit it.
    Dec 2007
    2,977
    Received: 287/0
    Given: 30/1
    14
    Odd... If I had enough volume.. I would just put an 8 ohm resistor in series with the 8 ohm speaker then. At least try it before changing the speaker. A lot cheaper and may be just fine.
    Supporting Member
    Mar 2018
    Germany
    2,260
    Received: 1,718/1
    Given: 974/2
    5
    That would be a simple power attenuator. The series resistor wll dissipate up to 50% of output power.
    - Own Opinions Only -
    Dec 2007
    2,977
    Received: 287/0
    Given: 30/1
    14
    Well.. sort of. The perception of volume will not be 50% less... especially if the amp isnít dimed.
    Senior Member vintagekiki's Avatar
    Jul 2006
    1,594
    Received: 269/1
    Given: 221/0
    16
    Quote Originally Posted by retool View Post
    Only correctly connects the speaker with various resistance to the amplifier is via the impedance matching transformer.
    http://www.voxsupreme.org.uk/vox_multi_link_transformer.html
    https://www.tonefactory.nl/impedance-matching-transformer-marshall-original-nos-used-in-models-2200-and-2098
    https://drtube.com/schematics/marshall/2200-pwr.gif
  1. Tube amp (reel to reel / guitar) "Output" to speaker question???...
    By tubula in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-03-2017, 09:44 PM
  2. VOX AC-15 1x12"spkr -----COVER
    By popoahi in forum Other Amps
    Last Post: 02-04-2014, 01:52 AM
  3. Peavey Bass amp making "bad speaker" sounds at high volume, but speaker isn't bad
    By wizard333 in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-27-2011, 12:30 PM
  4. Warehouse Guitar Speaker: "Black and Blue" released
    By TD_Madden in forum Mods & Tweaks
    Last Post: 05-24-2011, 02:09 AM
  5. Recommended speaker for 1x12" cab
    By selmer in forum Build Your Amp
    Last Post: 10-03-2007, 07:23 PM
