If you are going to the trouble of building one of these.. I would strongly suggest you find a Champ or a VJ or some little 5 watter and simply put a voltage divider on the speaker out and try it. That’s virtually what these are. They are a real one trick pony and difficult to use.. which is why you don’t see them used much btw. I guess you could build a champ with a switch to convert it to this mode? Or you could get a VJ head from CL for $80 and convert it.
Garnet Herzog questions
Originally posted by Randall;532585
[/BThat's not the way I read it. I see a direct connection to the input/output junction in bypass mode to the 150K. Correct me.
Connected: Bypassed:
The circuit input and output are not connected at all in the bypassed state.
Originally posted by mhuss View PostThe top post schematic has a DPDT switch. Here is how the signal is connected and bypassed:
Connected: [ATTACH=CONFIG]54078[/ATTACH] Bypassed: [ATTACH=CONFIG]54079[/ATTACH]
As far as I know, that is the one being discussed.
Perhaps Randall can clarify.
Here it is again:
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
