Need Schem for Teisco Checkmate-15 tube amp
  • Need Schem for Teisco Checkmate-15 tube amp
    Need Schem for Teisco Checkmate-15 tube amp, ...anybody?
    -Brad
    ClassicAmplification.com
    How close are the 18 and 20 on SChematic Heaven?
      Dunno how close, I got a Checkmate-20 schem (not from Schem Heaven) but I don't have the unit on the bench yet to see.
      I'm trying to do some preliminary research before the unit arrives, I've never seen one of these amps before.
      -Brad
        I draw my own all the time. A simple amp like this shouldn't take more than 20-30 minutes. Especially if it is similar to the others. Then you can rough the drawing out beforehand.
          Yes, I do too.
          My request was not of despiration, it's just that I've learned over the years that every single thing that comes across my bench needn't be a throw-down challenge.
          I often try to minimize my time by gathering data/info/schems of units I work on. I have a long list and it doesn't seem to get any shorter.
          Thanks for your input though,
          -Brad
          -Brad
            I understand. I have been slowly uploading my collected stuff to LArry at Schematic heaven, and elsewhere as seems appropriate. The Schematic Heaven site and Aspen Pitmann's disc are a good start to a collection. Somewhere I have an old Sams book which includes a lot of old odd amps.
              Yeah archiving schems is a great thing, good'on'ya.
              Speaking of SAMS, they used to have these things called Sams Photofacts which were like info packets on a series or Radios or TV's.
              When I was a teenager just learning about electronics an old guy I knew who retired from his own old radio shop gave me his entire set of Sams Photofacts, it was like 6 big 'ol boxes of 'em literally hundreds, with all kinds of tube based appliances.
              Well this was back in the late 60's/early 70's when everything was going to solid state and except for guitar amps and old Bogen PA's (which were not in the photofact set's) well I never ran into anything to use them for, everybody was ditching their tube stuff and buying solid state stuff... so I tossed them out... boy was that a bad move, I've regretted it ever since the late 80's when tube stuff started being popular again, specially the tube HiFi market.
              Sheesh! live-n-learn I guess.
              -Brad
              -Brad
                Threw out a Photofact collection? Go sit in the corner. I still have service manuals for littel Perpetuum Ebner phonograph players. And I cannot make myself heave the old GE stereo record player manuals.
                A friend brought over a little three tube record player amp that we messed with. I don't know what it was, but a schematic for it now resides in my files.
                  Just to follow up on this, it turns out the Checkmate-15 and Checkmate-20 are close enough to use the same schem-o.
                  I located the Checkmate-20 schematic on the internet and when the Checkmate-15 amp came across my bench I checked it against that schem-o, only a couple of very minor differences, like the voltage-doubler circuit (.002 caps across the diodes) and a different voltage on the plate's (320vdc).
                  The Teisco was a very well built amp I must say, never seen one before this and I was impressed with most of it (except the cheasy voltage-doubler power supply like Danelectro/Silvertone) it used PiO caps in the audio path and all wirewound resistors.
                  -Brad
