What could be the cause of the bias dropping lower e.g. 30ma dropping to around 13ma per EL34 tube when the volume master pot 250k is fully off? If you raise the volume pot the bias draw starts building back up to 30ma.
Bias drift when volume engaged.
You might be looking at it backwards. (why is tube conducting more when volume is raised above zero)
Hum or oscillation could be reasons.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by The Dude View PostHard to say without seeing a schematic of the circuit or even knowing what amp we're talking about.
https://drtube.com/schematics/hiwatt/hwpre1.gif
https://drtube.com/schematics/hiwatt/hwpsu1.gif
https://drtube.com/schematics/hiwatt/hwpwr100w.gif
The master in the schematic is 220k. I could assume that a 250k was used as a "nearest standard value". Or I could ask if we're all certain that the master circuit is just as shown in the schematic and the design has not been altered to a different master circuit.?.
Otherwise I agree with g1 that there could be a possibility of oscillation. Check lead dress and grounds."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostThe master in the schematic is 220k. I could assume that a 250k was used as a "nearest standard value". Or I could ask if we're all certain that the master circuit is just as shown in the schematic and the design has not been altered to a different master circuit.?.
How new are the filter caps? I'm also wondering if the amp is oscillating or motor boating. If so, it could easily be a bad filter cap or caps. Do you have a scope?
Edit: Also, what happens to your bias supply voltage when this happens. Does it stay consistent?"I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by Ampzone View PostWhat could be the cause of the bias dropping lower e.g. 30ma dropping to around 13ma per EL34 tube when the volume master pot 250k is fully off? If you raise the volume pot the bias draw starts building back up to 30ma.
Are you wondering why it drops/rises at all, or you're thinking it drops/rises too much?
Originally posted by g1 View PostSo there is no sound or hum that increases when volume is turned up?
You are not answering the question about what you are hearing through a speaker.
Any hum, or frequency above or below our hearing will change the tube idle current when the master is not at zero.
You need to listen to a speaker connected, and also scope the output in case it is not an audible frequency (oscillation).
You should not expect the draw to stay the same for all settings of the pots because there are exceptions.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Another question, and just to be clear: These symptoms are with no signal applied?
I have to wonder how you discovered this. I don't think I've ever fiddled with knobs while biasing an amp."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by m1989jmp View PostEvery bias tip I've read so far states that bias current is measured with (at least) vol down. You're measuring IDLE current that way. I suppose when you bring the volume up, something non-static happens, right?
I noticed the bias kept changing, new tubes I like to check a few times. so I checked it again and when I turned the volume lower and noticed the DMmeter dropping the ma current to around 13ma per tube from around 27ma per tube when the vol is dropped fully to 0. With speaker attached there is no unusual hum, oscillation or noise save the typical hiss and noise sound floor that drops when you lower any amp volume to 0. The presence control has the same effect on the bias ma. Yes, I think a drop of almost 15ma
per tube at idle no signal /speaker attached/ with a twist of vol knob is odd
Continuing to hunt for a bad ground---
