Results 1 to 3 of 3
Thread: EPK pcb troubles
    Aug 2007
    212
    Received: 5/0
    13
    EPK pcb troubles
    Hi, I got some EPK pcbs I ordered from their site https://effectpedalkits.com
    Checking the pcbs I fould out that they are faulty, missing continuity between several soldering pads, e.g. no continuity on grounds etc.. Asking meanwhile several times for fixing, replacement or checking their obviously faulty designed pcbs, I got no answer from EPK.
    Any similar bad experiences with EPK pcbs?
    Thanks for reply
    Zouto
    Aug 2007
    212
    Received: 5/0
    13
    Problems solved, after a short time I finally got an answer, rechecked pcb and wiring, replaced a bad cable, the circuit is working fine now. The pcb was ok, internally broken ribbon cable was the culprit.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,581
    Received: 1,736/18
    Given: 1,337/29
    26
    Quote Originally Posted by Zouto View Post
    Just curious (very) about your:
    a
    broken ribbon cable
    does not explain that.
    Care to elaborate?
    Maybe post a PCB picture and say: "I didnīt have continuity between here and here"
  1. VHT Pitbull 45 troubles
    By Zouto in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-22-2019, 12:54 AM
  2. Mod Troubles !
    By Valvehead in forum Mods & Tweaks
    Last Post: 01-30-2013, 04:02 AM
  3. SWR SM-900 Troubles
    By DominoTree in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-24-2011, 11:10 PM
  4. Amp troubles!
    By stickmanoncrack in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-17-2010, 03:58 PM
  5. JCM 600 troubles
    By Rockworth in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-04-2009, 08:21 AM
