Results 1 to 19 of 19
Thread: Stratocaster, refinish or leave it as it is ?
    Feb 2019
    Portugal
    33
    Received: 12/0
    Given: 17/0
    0
    Hey guys, i have this beautiful 2018 american special stratocaster in sonic blue, bought it new and intend to keep it forever, HOWEVER, i didn't expect the paint to be this sort of thick plastic coating (polyurethane) which i now reckon will never age (at least not like the vintage strats).
    I'm considering a NITRO lacquer refinish (professionally done), and i'm aware i'll be devaluing the instrument, just wanted to know what are your opinions on this because it's always good to see things from different perspectives and i might be missing something worth considering.
    PS: i've played for years with my father's 70s sunburst strat and i love it, this is why i got a strat with big headstock in the first place, it's supposed to be my definite/number one guitar
    Aug 2015
    Edmonton, AB
    287
    Received: 249/3
    Given: 123/3
    5
    I also don't like those thick plastic-y feeling poly finishes.
    Some poly finishes are ok, like my older Deluxe Nashville Tele has. (sunburst)
    It's poly but seems thin-ish, and doesn't feel like the whole thing was dipped in plastic.
    Being poly it will never "age" like nitro, but I'm ok with that.
    If you are keeping it forever, then sure, strip it and have a nitro finish applied.
    Only caveat would be, if you go for a transparent or semi transparent finish, like a sunburst,
    you might be surprised at what is hiding under that solid color. (good or bad)
    If you have it refinished in a solid opaque color, then it won't matter what the wood underneath looks like.
    FWIW I stripped a cheap pawnshop Strat type guitar for the same reason. (thick plastic finish)
    It ended up being plywood, so I did a solid opaque finish.
    Good luck whatever you decide!
    1 Not allowed! Not allowed!
    The world is full of people that are right.
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    11,815
    Received: 1,089/32
    Given: 1,039/14
    22
    I wouldn't refinish it.
    I would instead trade it for a reissue that has the nitro finish.
    GL,
    T
    4 Not allowed! Not allowed!
    "If Wishes Were Horses, Beggars Would Ride!" Scottish Proverb 1600s
    Oct 2015
    NEPA
    878
    Received: 220/2
    Given: 159/0
    5
    Have fun removing the old poly. Not easy.
    It would be much easier to buy another body and finish it how you want. You can get generic strat bodies as low as $45.
    5 Not allowed! Not allowed!
    Supporting Member
    Nov 2016
    Nova Scotia
    226
    Received: 116/1
    Given: 298/1
    4
    I agree that refinishing is not the way to go. The easiest thing might be to get another body, either prefinished or finished to your specs, and then rebuild the guitar with that. That way you will still have the original body along with whatever value that has.
    3 Not allowed! Not allowed!
    May 2010
    Sioux Falls, SD
    6,904
    Received: 1,681/2
    Given: 1,210/1
    18
    If it's just the "too shiny" thing that bothers you (I don't like it either). You can take a Scotch-Brite pad and carefully scuff the finish a bit. Then, give it a light buffing to taste. It will take some time, but will dull the finish enough to make it look much like a nitrocellulose finish. I've done this on a few Epiphone Les Pauls and they look much better, IMO.
    Edit: Here's an example of one.
    https://imgur.com/gallery/9uV56
    Old Timer olddawg's Avatar
    Dec 2007
    La Jolla CA, Kapaa Kauai
    3,312
    Received: 477/6
    Given: 56/1
    16
    There is a plethora of boutique replacements bodies out there in infinite nitro colors if you look. You could also sell your new USA body for decent money. I guarantee someone wants it. Not everyone has the same asthetics...
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    16,430
    Received: 3,067/5
    Given: 3,705/0
    32
    This works. But you have to use the "fine" scotch bright pad. The white one.
    But I think it's the "age to yellow pea green" thing that the OP is wanting. Something the catalyzed finish is never going to do.
    Have you seen the finish on some of the "distressed" guitars coming out of the Fender custom shops? I swear they look like they were done in a couple of coats with rattle cans. It's pathetic. You can actually do a very good job with rattle cans, but these look like two coats of hardware store Krylon straight to the wood with two coats of spray can lacquer on top left unpolished. Shameful.
    May 2010
    Sioux Falls, SD
    6,904
    Received: 1,681/2
    Given: 1,210/1
    18
    Oh yes. I agree- the fine Scotch-Brite pad. And, best to start on the back till you get the hang of it and see what it's going to do. Don't be afraid, you can always buff it back smoother. That polyurethane finish is thick. I also added a link above, so you can see the effect of doing this. As I said, I have done this myself and am quite happy with the results.
    Feb 2019
    Portugal
    33
    Received: 12/0
    Given: 17/0
    0
    Thumbs up
    thank you all for the replies, you gave me a lot to think about ! I should have also mentioned that i want to keep it sonic blue, it's the finish that bothers me
    Quote Originally Posted by galaxiex View Post
    I also got a tele with poly finish but at least it is possible to see the wood grain, so i imagine it's either not as thick or simply transparent
    Quote Originally Posted by big_teee View Post
    GL,
    T
    There's one issue with my father's guitar, i has the three bolt on neck wich is sort of unreliable, 4 bolt is the way to go
    Quote Originally Posted by mozz View Post
    I wouldn't be removing it myself, this would be done by a professional who's proven to deliver good paint jobs, he quoted me 150€ and 3 months to get it done (He's friends with a friend of mine who plays for a living).
    As for the generic strat bodies, i would need to check the quality differences between mine and aftermarket
    May 2007
    pacific north west
    16,430
    Received: 3,067/5
    Given: 3,705/0
    32
    Quote Originally Posted by brunobliss View Post
    If you have good reason to believe in this guy that's an amazing price for Sonic blue with nitro finish over existing or after stripping. A Warmoth body (alder, Sonic blue, nitro) would be about $390 US!!!
    The original paint on the vintage instruments was enamel (a vague term that could mean a lot of things actually) made by "Duco" (?) I think that was the name. And then plain nitro on top. Enamels of different types have their own age and discoloration properties. And then lacquer has it's own. I seriously doubt that one could hope for a vintage correct finish that would age like the original being applied by anyone now. JM2C.
  12. #12
    Feb 2019
    Portugal
    33
    Received: 12/0
    Given: 17/0
    0
    Well i been giving this a lot of thought and after considering it all i might leave it as is, maybe in the future i'll just end up getting my own custom shop strat and make it right. For now i'm keeping this all original <3
  13. #13
    May 2007
    pacific north west
    16,430
    Received: 3,067/5
    Given: 3,705/0
    32
    Well there are still options. Maybe in five or ten years when it has some scratches and dings, the "new guitar smell" has worn off and if you find it's not becoming a really expensive collector model you could "distress" it and spray on a coat of amber tinted finish to get close to that sickly green color everybody loves Sure, it's fake mojo, but it still looks cool.
  14. #14
    Feb 2019
    Portugal
    33
    Received: 12/0
    Given: 17/0
    0
    knowing myself very well, the idea won't go away until i do something about it only time will tell
  15. #15
    Professional Lurker eschertron's Avatar
    Aug 2012
    Great Black Swamp
    2,363
    Received: 521/0
    Given: 1,366/1
    11
    Oh, now that's real nice guitar porn
    2 Not allowed! Not allowed!
  16. #16
    May 2007
    pacific north west
    16,430
    Received: 3,067/5
    Given: 3,705/0
    32
    I hadn't even considered that angle. It's on the bed. It's strap is off the buttons. The lights are down low...
  17. #17
    Aug 2012
    Great Black Swamp
    2,363
    Received: 521/0
    Given: 1,366/1
    11
    Yeah, it's the old lecher in me, I guess...
  18. #18
    May 2007
    pacific north west
    16,430
    Received: 3,067/5
    Given: 3,705/0
    32
    Gotta give you props for actually experiencing that sensation looking at a guitar (in any context). I mean, we joke about it, of course. But you actually saw, and cognitively processed the connection. That's a guitar man if I ever knew one
  19. #19
    Feb 2019
    Portugal
    33
    Received: 12/0
    Given: 17/0
    0
    Based on your opinions / suggestions and went ahead and got myself (finally!!) a SURF GREEN Nitro finish strat body!
    This is a 3 piece american alder body (exactly like my current strat). Would prefer to naturally age it myself but couldn't pass on this great deal:
    From "Baldman" (http://baldman-guitar-relics.blogspot.com/)
    Absolutely LOVE the feel of it, also being able to see the wood grain pop from the finish is just what i wanted.
  1. Class D - ok to leave on channel unused?
    By Guitarist in forum Theory & Design
    Last Post: 03-24-2016, 12:11 PM
  2. Replies: 6
    Last Post: 08-23-2015, 03:33 AM
  3. How to leave my '72 Bassman ?
    By Chevy in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-20-2014, 05:03 PM
  4. stratocaster
    By popoahi in forum Guitar Tech
    Last Post: 01-12-2014, 10:44 PM
  5. How to refinish mahogany body?
    By casey73 in forum Guitar Tech
    Last Post: 05-16-2008, 04:01 PM
