Results 1 to 10 of 10
Thread: buzz / hiss in SS stereo power amp
    New Member
    Jun 2019
    1
    0
    I have a noisy / buzzy / hissy sound coming from my Randall RRM 2-80 power amp. It's loud enough to be obnoxious, and definitely didn't come that way from the factory, so I'm assuming something is failing. One thing that is unique about this series (or that is my understanding) is that they have a switch in the back that provides a way to select between constant voltage and constant current. I'm not sure what the goal in that would be, but I can tell you that for guitar rig purposes, it sounds better on constant current. Let's assume the buzzing noise is consistent regardless of the switch position. What's the best way to diagnose the issue? Is there a "typical" component that starts failing after, say, 25 years? (Obvious semi-newby question).
    Last edited by marc9889; 06-25-2019 at 05:43 PM. Reason: image not being displayed
    Near Dallas Texas
    3,549
    Received: 240/0
    Given: 116/1
    18
    If you can find a schematic, either post it or a link to it here so everyone is on the same page.
    This is just a WAG, Wild Ass Guess. I'm assuming the circuit is basically the same as the RG-100 guitar amp that has been around for like forever. The input transistors of a typical solid state power amp can be degraded if they are over driven too hard or too long. It's usually reverse base to emitter breakdown. Many power amps have no protection on the inputs, driving them with a tube preamp can kill them. The transistors will become noisy before they fail outright. So carefully remove the existing transistors and try to find exact replacements. If possible, I would install sockets.
    1 Not allowed! Not allowed!
    Dec 2009
    Devon, UK
    3,594
    Received: 796/1
    Given: 616/1
    14
    It's stereo. Do both channels have the identical level of hiss?
    Suggest you measure and report the AC Vrms at the speaker terminals using a DVM with just the hiss present.
    Dec 2008
    Wernersville, PA
    13,003
    Received: 568/3
    Given: 298/0
    28
    Here is the schematic: RRM2-80 - Schematic.zip
    Good luck finding that 2N8098.
    Possible substitute?
    2N2060.pdf
    Sep 2011
    Pace, FL
    3,306
    Received: 1,161/102
    Given: 160/36
    12
    Quote Originally Posted by Jazz P Bass View Post
    Here is the schematic: Attachment 54157
    2N2060.pdf
    Schematic not working.
    Datasheet does.
    nosaj
    Sep 2011
    Pace, FL
    3,306
    Received: 1,161/102
    Given: 160/36
    12
    2N2060.pdf
    Looks to be still available.https://www.google.com/search?q=2n20...w=1366&bih=662
    nosaj
    Dec 2008
    Wernersville, PA
    13,003
    Received: 568/3
    Given: 298/0
    28
    Here is the OM.
    RRM2-80-OwnersManual.pdf
    There is a description of the differences in the Constant Current vs the Constant Voltage Selector Switch.
    Interesting.
    Dec 2008
    Wernersville, PA
    13,003
    Received: 568/3
    Given: 298/0
    28
    Quote Originally Posted by nosaj View Post
    Reloaded it as a zip file.
    https://music-electronics-forum.com/...2&d=1561943639
    Dec 2009
    Devon, UK
    3,594
    Received: 796/1
    Given: 616/1
    14
    2N2060.pdf
    Well spotted. Those are expensive at $30 a pop.
    You can substitute a pair of transistors such as KSC1845 that are inexpensive. For best results super glue them with the flats touching each other.
    Supporting Member nevetslab's Avatar
    Apr 2010
    Burbank, CA
    1,839
    Received: 665/1
    Given: 1,506/1
    11
    Quote Originally Posted by nickb View Post
    A
    NICE NPN part! If you do change to these, you'll need to reform the leads, as the pinout is different. Facing the flat, left pin is E, middle pin is C, right pin is base
  1. Replies: 2
    Last Post: 01-21-2018, 10:28 PM
  2. Power transformer for homebrew SE stereo ECC99 power amp
    By jamesmafyew in forum Build Your Amp
    Last Post: 04-14-2012, 10:10 PM
  3. Amp buzz / rattle / hiss on certain notes
    By switters in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-11-2011, 11:39 PM
  4. Marshall jcm 900 2100 noisy buzz/hiss/squeal
    By lespaul924 in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-28-2011, 05:35 AM
  5. JTM 45 Clone buzz/hiss
    By markammon1979 in forum Debugging Your Build
    Last Post: 12-26-2009, 03:28 PM
Tags for this Thread
