Marshall TSL 100 - Emulated line out, very strong hum
  • Marshall TSL 100 - Emulated line out, very strong hum
    Hey folks,
    I need some help repairing a Marshall TSL 100!
    Its gives a very strong humsignal at the XLR jack. Even when I put out the valves and the PI. And when I disconnect the con1
    Any Ideas???
    Cheers Chris
    https://www.thetubestore.com/lib/the...-Schematic.pdf
    IC1 is the whole circuit, so look at the output pins - the corners - and see if any are stuck on DC.
    The IC runs on 15v supplies, so check those for ripple and voltage.
      Thank you!
      Unfortunately I´ve got no Oszilloskope. Do I have chance without?
        You look for voltages with a volt meter.
        Certainly a meter will find unwanted DC on op amp pins. It will also find low power supply voltages. Your particular meter may or may not measure riple well, but do the other things first.
          Ok, the 15V+ and 15- are ok
          On some other pins I find about 3mV DC ???
