While putting a true bypass switch in a friend's Cry Baby, since I had extra terminals on the switch, I added a LED on/off indicator. I had run out of my supply of LEDS, so I pulled one out of an old bike light. This light has 3 super bright red LEDs, some kind of chip under a glop to make it blink, etc., and is powered by two AAA batteries. It didn't occur to me until it was finished that maybe I should have considered that it is now being powered by 9v, with no others to share the load. I currently have (see what I did there?) it in series with a 1.5K resistor. It has been on for an hour now with no trouble, but is it OK like this, or do I need a bigger resistor. And just how would I know?
LED question
What's the voltage drop across the resistor? Since the resistor and the diode are in series, they must pass the same current. Calculate the current through the diode using the 1.5k resistor voltage drop. Then determine how much current you really need. Adjust dropping resistor as desired.If it still won't get loud enough, it's probably broken. - Steve Conner
Since you can't know LED specs (robbed form a bike light), it's anybody's guess. I'd start with a large resistor and work my way down in value until the LED was bright enough for your purpose. This will be the least likely to harm the LED and use the least amount of battery."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by The Dude View PostSince you can't know LED specs (robbed form a bike light), it's anybody's guess. I'd start with a large resistor and work my way down in value until the LED was bright enough for your purpose. This will be the least likely to harm the LED and use the least amount of battery.
Back in the early 90's when super brights just became available, I swapped out the LED's in my Peterson strobe tuner. Now plenty visible in daylight without having to use an annoying makeshift cardboard cone gaffer taped over the display. H'ray for science!This isn't the future I signed up for.
Originally posted by Randall View PostWhile putting a true bypass switch in a friend's Cry Baby, since I had extra terminals on the switch, I added a LED on/off indicator. I had run out of my supply of LEDS, so I pulled one out of an old bike light. This light has 3 super bright red LEDs, some kind of chip under a glop to make it blink, etc., and is powered by two AAA batteries. It didn't occur to me until it was finished that maybe I should have considered that it is now being powered by 9v, with no others to share the load. I currently have (see what I did there?) it in series with a 1.5K resistor. It has been on for an hour now with no trouble, but is it OK like this, or do I need a bigger resistor. And just how would I know?
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
Originally posted by Leo_Gnardo View PostThis ^^^ . And those super brights are way efficient, you'll be burning your retinas I'm sure with just a couple milliamps. Some local musos have asked me to put them in pedals so they can see them in daylight. On a reasonably dark stage, they shoot a beam of color light onto the ceiling - woooo, psychedelic !
Back in the early 90's when super brights just became available, I swapped out the LED's in my Peterson strobe tuner. Now plenty visible in daylight without having to use an annoying makeshift cardboard cone gaffer taped over the display. H'ray for science!"I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
The voltage drop across the 1500R is 10.8v, so 10.8/1500 = 0.0072, or 7.2mA. That seems relatively safe, doesn't it?
Or does it? I put in a 3K resistor for half the current at 3.6mA. Not as super bright, but probably safer.It's weird, because it WAS working fine.....
IMO, figuring current is pointless since you don't have LED specs. There are LED's rated from 1mA to 70+mA. The best you can do is eyeball it, which should be close enough."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by Randall View PostThe voltage drop across the 1500R is 10.8v, so 10.8/1500 = 0.0072, or 7.2mA. That seems relatively safe, doesn't it?
So, I would take the advice above and start with a large resistance–working your way down until you can see a brightness you can live with at the lowest current. Do this in low light, for the reasons the Dude and Leo said. The big one is LEDs are really directional, and on a dark stage, they can be annoyingly bright. My guess is that you should see a reasonable brightness at 3-4mA. But if you can do it at 1-2mA, even better.If I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
Originally posted by SoulFetish View PostI would trust The Dude on this, he's been a technician much longer than I..."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by Leo_Gnardo View PostSome local musos have asked me to put them in pedals so they can see them in daylight.
Sure, but in daylight they are impossible to see
I ran across an old Boss pedal that had an external supply jack, but it wouldn't run on the typical 9V pedal board supply. It wanted a special Boss 12V floating supply. The LED wasn't very bright.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
I'd like to stock up on some general purpose LEDs. Looking at Mouser, which is more important, forward current rating, or forward voltage? Interesting, they don't offer 9v, it jumps from 7.5v to 12v. They don't have to be high intensity.It's weird, because it WAS working fine.....
