Results 1 to 4 of 4
Thread: Carver PX1450 one channel down
  1. #1
    Join Date
    Sep 2012
    Location
    South coast UK
    Posts
    664
    Thumbs Up/Down
    Received: 27/0
    Given: 40/0
    Rep Power
    8
    Hello all
    this one is starting to try my patience a bit
    It came in for protection mode on one channel. while i was testing about. I found a short across a 26.4k resistor R371
    I removed the resistor, resistor fine but short to ground from Base of Q333. It turned out that the though hole plated track was touching ground though the board, as they did sit very close to each other
    sorted that out by cutting the track to the base and wired the resistor from ground to base point to point
    carver_px1450_px-series_rev.c_amplifier.pdf
    Tested ground to base of Q333 is now at 26.4k
    Turned on then R363 ( 1k) and R372 ( 1.8k) and R21 ( 10R ) went up in smoke
    I have tested all semi conductors and compared to other side.I can't find any short circuits
    further investigation i found R362 ( 33R) to have blown
    when i switch on now R372 ( 1.8k ) goes up in smoke
    While looking at the map i noticed the same place on the good channel R476 is 270R where on the faulty channel is 27.6k
    If anyone has a thoughts or assistance
    BBB
    0 Not allowed! Not allowed!
  2. #2
    Join Date
    Feb 2010
    Location
    Posts
    12,338
    Thumbs Up/Down
    Received: 2,012/24
    Given: 5,115/11
    Rep Power
    24
    Do you have a good connection from Q333 base to Q336 base?
    Is Q336 base maybe also grounded by the same defect?
  3. #3
    Join Date
    Sep 2012
    Location
    South coast UK
    Posts
    664
    Thumbs Up/Down
    Received: 27/0
    Given: 40/0
    Rep Power
    8
    Yes G1 I checked that. that's ok. I have pulled the semi conductors out the board from that area, can't find anything
  4. #4
    Join Date
    Feb 2010
    Location
    Posts
    12,338
    Thumbs Up/Down
    Received: 2,012/24
    Given: 5,115/11
    Rep Power
    24
    Is Q331 ok? It could account for R372 and R363 problems.
    Quote Originally Posted by blindboybenton View Post
    Did you verify with resistance checks in the actual circuit board? Could be a typo I suppose.
Thread Information
Users Browsing this Thread
  1. Carver FTM-25
    By lowell in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-24-2017, 04:26 AM
  2. Carver PT2400 insight needed
    By Mick Bailey in forum Other Amps
    Last Post: 09-26-2015, 05:55 PM
  3. Carver PM350 stereo power amp
    By Brad1 in forum Music Electronics
    Last Post: 07-23-2009, 11:40 AM
  4. Carver M-1.5t THUMP at Power Off
    By bob p in forum Other Amps
    Last Post: 06-23-2009, 03:28 AM
  5. Fault Tracing a Carver M-500t
    By bob p in forum Music Electronics
    Last Post: 08-28-2008, 11:13 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
