Results 1 to 7 of 7
Thread: Solid state Marshall Amp squeeling while turning pots
    Twobie
    Jul 2019
    3
    0
    Hello dear MEFrs,
    I'm trying to keep it as short as possible:
    My Marshall MG50FX screeches when im turning any pot (except Master). Master seems to just amplify the noise. The noise is the same with every pot. White noise from amp starts 2-3 seconds after switching on. It still picks up the guitar, but not as loud as it should.
    What I've tried:
    -Checked most of the capacitors.
    -unplugged the speaker and used headphones instead-> Exactly the same result
    So, hopefully someone of you knows more than me and can give me some clues.
    I'll link an audio of the issue.
    Thanks a lot!
    Palomacy
    Audio file of screeching noise(VOL. WARNING) :
    https://drive.google.com/file/d/1SHr...w?usp=drivesdk
    Supporting Member
    Staffordshire UK
    3,671
    Received: 409/1
    Given: 394/1
    18
    How exactly did you check the caps? eg ESR assessment.
    Schematic file or link?
    If no schematic available then best to raise another topic in that regard in the ‘schematic request’ sub forum.
    Twobie
    Jul 2019
    3
    0
    Thanks for the quick answer!
    I checked all of them for exterior damage and soldered half of them out and checked them with a multimeter one by one.
    Supporting Member
    Staffordshire UK
    3,671
    Received: 409/1
    Given: 394/1
    18
    The parameters of ecaps that fail with age / use are ESR and leakage resistance. Unless you have checked those your testing was insufficient.
    Dec 2008
    Wernersville, PA
    12,828
    Received: 452/2
    Given: 237/0
    25
    I am not sure if there even IS an MG50FX schematic.
    If there is, it has never surfaced.
    If the front end is anything like the MG15-30 FX, there is a bunch of DSP, atmeg microcontroller stuff going on.
    So the controls are feeding the microcontroller.
    That is what the 'FX' indicates.
    Here is the 15-30 schematic:
    MG15_30FX.pdf
    The 50FX uses a TDA7293 output ic:
Name:	MG 50fx_tda board.png
    Senior Member mozwell's Avatar
    Sep 2009
    Australia
    650
    Received: 9/0
    10
    MG50DFX, not sure if this is close enough
    Attached Files Attached Files
    Twobie
    Jul 2019
    3
    0
    Hello guys!
    I appreciate your help! Yesterday I soldered some more capacitors out for testing and found some faulty ones on the output ic board. Hope that fixes the problem. I'll take a look inside the schematic and see if it matches.
    Thanks again and I'll tell you if it worked!
  1. Solid state amp with OT?
    By überfuzz in forum Guitar Amps
    Last Post: 08-22-2016, 04:32 PM
  2. Marshall 2098 Solid State Lead 100 Repair
    By Billy R aka DynaFreak in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-04-2011, 06:27 PM
  3. Marshall 2205 Solid State Slave Head
    By Ted in forum Schematic Requests
    Last Post: 10-18-2010, 05:21 PM
  4. Solid State Marshall MG50DFX
    By Pablomago in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-30-2007, 04:16 PM
  5. Loud Buzz from Marshall Valvestate 65 (solid state)
    By markh99999 in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-02-2007, 07:49 PM
Tags for this Thread
