Page 2 of 2 FirstFirst 12
Results 36 to 53 of 53
Thread: Jet city JCA20H mod - can't find schematics or instructions
  1. #36
    Aug 2015
    Ecuador
    56
    Received: 13/0
    Given: 39/0
    5
    Thank you.
    I will get the gain pot out to measure it with my multimeter.
    Probably it is a commercial log pot.
    I really appreciate the help everyone is giving with this thread, and all the link provided.
    1 Not allowed! Not allowed!
  2. #37
    Aug 2015
    Ecuador
    56
    Received: 13/0
    Given: 39/0
    5
    This is the way I understood the instructions.
  3. #38
    Senior Member vintagekiki's Avatar
    Jul 2006
    1,600
    Received: 270/1
    Given: 223/0
    16
    Quote Originally Posted by spunko View Post
    Approximately
    View Marshall Clean / Crunch circuit, and analyze the signal path of the part schematics V2a / V2b (switch SW5)
    https://drtube.com/schematics/marshall/6100-61-04%20iss9.pdf
    Clean/Crunch circuit
    https://drtube.com/library/schematics/69-marshall-schemas#AN30
    Marshall 6100
  4. #39
    Aug 2015
    Ecuador
    56
    Received: 13/0
    Given: 39/0
    5
    Quote Originally Posted by vintagekiki View Post
    Approximately
    Marshall 6100
    I haven't tried this solution in the amp yet.
    I have looked at the marshall circuit, but I don't understand what I need to get this mod right.
    I have followed the signal path (I think) and it is basically the same as I have understood, my AC signal comes amplified from the plate of A (1st half) and gets inyected into greed of the second half to get amplified and goes out from the plate of the second half. That would be the normal path.
    With the mod, the singal bypasses the second half of the tube and goes to the second tube.
    The marshall switch circuit is more complex for my understanding, I don't get why it feeds the signal back to the grid of the second half, if the intention was to bypass that half.
  5. #40
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,753
    Received: 1,881/23
    Given: 1,463/35
    27
    Have you at least tried the simple solution I suggested?
  6. #41
    Cheshire, UK
    2,234
    Received: 540/4
    Given: 287/0
    16
    How can I mod it to clean the sound, or lower the gain?
    I'd try connecting a resistor in parallel with the gain pot VR6
    Gain reduction would be 15dB using 100k, 20dB using 56k.
    Both sides of the pot are at ground potential so there shouldn't be any pops when switching the resistor. Tone should be unchanged unlike when switching out the cathode bypass caps.
  7. #42
    Cheshire, UK
    2,234
    Received: 540/4
    Given: 287/0
    16
    Too easy
  8. #43
    Jul 2006
    1,600
    Received: 270/1
    Given: 223/0
    16
    The Clean / Crunch schematics is as an idea of how the signal path is going.
    Tube V2b gives gain for crunch.
    Schematics for Crunch is your personal choice, it is important is select choice Clean / Crunch. In Clean mode g1 V2b (crunch tube) via SW5a and R24 binds to ground so that V2b does not oscillate.
Name:	Clean & Crunch.jpg
    Path Signal for Clean (Red)
    Path Signal for Crunch (Green)
    Choice Clean/ Crunch (Blue)
  9. #44
    Aug 2015
    Ecuador
    56
    Received: 13/0
    Given: 39/0
    5
    I'm sorry for the late reply, I was out of town.
    Thank you for the help. As I understood, it is necessary that 2b goes to ground via a resistor to avoid oscillation.
    is this ok?
    Also, I'm going to try Fahey solution.
  10. #45
    Aug 2015
    Ecuador
    56
    Received: 13/0
    Given: 39/0
    5
    **Edit: I was asking for help in this post, because the amp started to oscillate, even at stock (no mods). Sorry for the double post
    It turns out I forgot to clean the flux from the PCB and it got conductive. Just after I asked for help, I cleaned it and the oscilation stoped.
    What do you think about the diagram above?
  11. #46
    Jul 2006
    1,600
    Received: 270/1
    Given: 223/0
    16
    Jet city JCA20H mod
Name:	JCA20H cc mod.jpg
    2 Not allowed! Not allowed!
  12. #47
    Aug 2015
    Ecuador
    56
    Received: 13/0
    Given: 39/0
    5
    Thank you very much, that is awesome!!
    One question, adding those resistors (1M and 2M2) wouldn't change the behavior or sound of the amp even in the crunch/normal mode??
  13. #48
    Jul 2006
    1,600
    Received: 270/1
    Given: 223/0
    16
    Resistors 1M and 2M2 do not affect the sound in any one mode.
    They generally serve to reduce the "click" that may possibly occur when switching SW1 from clean to crunch and vice versa.
  14. #49
    Feb 2010
    11,759
    Received: 1,615/23
    Given: 4,135/11
    22
    Why the change from 330K to 1M, is it so there is less attenuation on clean setting?
  15. #50
    Jul 2006
    1,600
    Received: 270/1
    Given: 223/0
    16
    The clean / crunch mode does not change the schematics JCA20H.
    Only added SW1 (clean / crunch switch) and "anticlick" resistors 1M and 2M2 .
    Resistors 1M and 2M2 do not participate in attenuation of the signal.
    1M provides polarization of g1 (V1a), and 2M2 allows "emptying" C24 when SW1b is in clean mode.
  16. #51
    Aug 2015
    Ecuador
    56
    Received: 13/0
    Given: 39/0
    5
    Thank you very much for the help.
    I tried vintage kiki diagram and so far so good.
    I'll give you an update in a couple of days.
  17. #52
    Aug 2015
    Ecuador
    56
    Received: 13/0
    Given: 39/0
    5
    Hello friends.
    An update to this thread. I tried J M Fahey in my first mod and it worked really well, but I ended up mixing it with another suggestion from another forum. (If you see my first diagrams) and the clean mod sounded really good, but when switched to gain/normal, and if you strum a chord, at the end of the trail the volume faded down and up again. This is the reason why I tried a different aproach with the suggestion I got from Dr. Olaf Krampe by email.
    Whe I switched back to normal, no mods at all, the amp stil behabed with the fade down/up problem, and it turned out to be flux residiu on the PCB that I didn't clean.
    Perhaps my first attemp would worked well if I had cleanned that flux residiu.
    Well, I tried the second mod suggested by Dr. Olaf, and improved by vintagekiki, and it is working great. It sounds really good.
    It drops the volumen quite a bit, but not that much to bother, and with the improved headroom, it sounds good and interesting. Like if its another amp.
    It would be awesome if we could still keep this thread alive, improving or changing the mod.
    *Edit:
    This is how I hooked the mod to the switch.
    Sorry vintage kiki for butchering your diagram.
  18. #53
    Oct 2007
    11,753
    Received: 1,881/23
    Given: 1,463/35
    27
    Oh, you can keep it alive , just test other options and post results.
    Glad you found a solution you like
  1. Sound City Schematics
    By Steve L in forum Schematic Requests
    Last Post: 10-30-2013, 02:38 PM
  2. trying to find acoustic model 470 schematics
    By bowesj in forum Schematic Requests
    Last Post: 04-21-2013, 01:13 PM
  3. trying to find acoustic model 470 schematics
    By bowesj in forum Repair and Restoration
    Last Post: 04-20-2013, 11:40 PM
  4. Alamo amplifier, anyone know where to find schematics?
    By Mr Johnny Birchwood in forum Guitar Amps
    Last Post: 01-10-2013, 05:53 PM
  5. Sound City SMF Tour KM2 schematics
    By bbmc in forum Schematic Requests
    Last Post: 11-16-2012, 10:25 AM
