pentode/triode switch
That is how it's usually done. That is, keeping the existing screen grid resistors in the circuit."Take two placebos, works twice as well." Enzo
Originally posted by Randall View PostTalk to me about switch rating.
Note the mighty Mesa uses Carling rocker switches, little rectangular ones also rated for 250VAC. Haven't seen any of them fail yet either. But I'm not gonna start cutting rectangle holes in chassis whether for mods or builds. Life is difficult enough.This isn't the future I signed up for.
I've used plain ol Alpha rotary switches and just doubled up the poles. By "electrical" standards it's not that demanding current wise. It's the voltage rating you need to pay attention to. I don't have a switch to recommend, but just look for a high voltage rating."Take two placebos, works twice as well." Enzo
So, per my orignal post, the 3A 125vac switches I have on hand aren't going to be reliable, sounds like. I have one in my Bassman build, and I have not experienced any pops or sparks with it.It's weird, because it WAS working fine.....
It’s the voltage ‘across the switch’ that is key. There isn’t much voltage difference between most screens and plates in most amps.Building a better world (one tube amp at a time)
Originally posted by tubeswell View PostIt’s the voltage ‘across the switch’ that is key. There isn’t much voltage difference between most screens and plates in most amps."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostBut because there's no shorting balance point there is NO voltage and then high voltage during the action of switching. Not to mention that the screen itself is disconnected from HV during the switching while it's likely conducting (so, rapidly draining current and voltage). I know that you're supposed to put the amp in standby before switching, but then there's the real world with real guitarists at the helm. I think a high voltage rated switch is a sage consideration in this circuit.Building a better world (one tube amp at a time)
"but if you keep a 1M permanently across the switch (as discussed in the previous posts), then the screen is not disconnected from HT at any time"
tubeswell can you elaborate on this? This has been the crux of my question.It's weird, because it WAS working fine.....
My concern is that at high signal levels there are kV between the power tube plates of inductively loaded amps; what's the breakdown voltage between the switch terminals and the chassis?
Plus the additional wiring etc kinda invites issues due to parasitic coupling from their radiated field.
Agree that regular quality brand switches seem to hold up in this application, but it's surely way beyond their spec / intended use.
But the biggest issue is that amps generally sound like ass when switched to triode mode, and may have a dollop of ring modulation added from HT ripple unless it's very well smoothed.My band:- http://www.youtube.com/user/RedwingBand
Originally posted by pdf64 View PostAt idle maybe; it may cause problems if the switch was flipped whilst under load.
The guys on this board helped me to fix it, and I added more capacitance to the screen when it was attached to the plate. That quelled the extra hum a bit (but not completely)... but all in all the change in tone didn't impress me that much, and I finally abandoned the idea in favor or other mods. One thing I really can't stand are loud ghost notes created by poor ripple filtering.
I'm sure a triode switch works quite well in some instances and on some amps and it does change the response and tone noticeably, but as pdf64 indicated, you might bring along some other bad sonic or leakage effects for the ride." Things change, not always for the better. " - Leo_Gnardo
My concern is that at high signal levels there are kV between the power tube plates of inductively loaded amps...
Originally posted by pdf64 View Post...
Plus the additional wiring etc kinda invites issues due to parasitic coupling from their radiated field.Building a better world (one tube amp at a time)
I won't argue about specs, but I'll add this: Anyone ever look at the voltage rating on a typical Fender standby switch?
Just sayin', if it works there, it should be fine for a pentode/triode switch."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
